Zabbix "failed to send email"
  • humroben
    • May 2018
    I initially setup zabbix to monitor my Ceph environment and to integrate with my Grafana instance. I had recently seen an issue with Ceph, and immediately started configuring triggers and the mail configuration. At present, the triggers work, and the monitoring is working as expected, however, I keep getting the following error when Zabbix attempts to send mail:
    failed to send email: Failed binding local connection end: bind failed with errno 99: Cannot assign requested address
    Here are my current email settings:
    SMTP Server: mail.citypaine.com
    SMTP Port: 587
    SMTP Helo: zabbix.citypaine.com
    SMTP Email: [email protected]
    Connection Security: StartTLS
    SSL verify peer: yes
    SSL verify host: yes
    Auth: User + Pass
    <valid auth details>
    I've already tested TLS using OpenSSL from the zabbix server, and this succeeds:
    # openssl s_client -connect mail.citypaine.com:587 -servername mail.citypaine.com -starttls smtp
    CONNECTED(00000003)
    Timeout : 7200 (sec)
    Verify return code: 0 (ok)
    Extended master secret: no
    250 HELP
    The mail server in question, is one that I've setup myself, and I can confirm that the Zabbix system is not attempting a connection to it.
    Any help on this would be appreciated.
  • humroben
    • May 2018
    Ignore this, I found my problem. There was an error in the "SourceIP" in the zabbix_server config file.
