The macros in operations do not work if they are from the child node
  • Alberto
    • Dec 2013
    I've upgrade to 2.2.1 from 2.0.7. I did not find any apparent problem, (except for Last Data and overview menu on frontend collapse cpu)...
    I've 2 nodes (master&child configuration). Now, when I receive a mail notification for a host from child node host.name and item.name macros become *Unknow*. Only fails with child node notifications from master node works ok.
    I've tried to change it for another macros adding "1" (hots.name1) with the same result.
    Trigger.name and trigger status works fine.
    Any Idea? may be data base
    Thanks.
    Albert.
  • Alberto
    • Dec 2013
    Example
    RECEIVED MESSAGE:
    Subject:
    DAB FUERA DE SERVICIO (CON ALARMAS ACTIVAS TIPO 1) EN *UNKNOWN* ESTADO: OK
    Message:
    *UNKNOWN* *UNKNOWN* 2014.01.17 09:37:26
    Error: DAB FUERA DE SERVICIO (CON ALARMAS ACTIVAS TIPO 1)
    Estado: OK
    Gravedad: High
    OPERATION CONFIGURED
    subjetct:
    {TRIGGER.NAME} EN {HOST.NAME1} ESTADO: {TRIGGER.STATUS}
    Message:
    {ITEM.NAME1} {HOST.NAME1} {DATE} {TIME}
    Error: {TRIGGER.NAME}
    Estado: {TRIGGER.STATUS}
    Gravedad: {TRIGGER.SEVERITY}
