UserParameter returns nothing
  • akbar415
    • May 2015
    • 119
    I create a small script to do tnsping through Zabbix.
    #!/bin/bash
    instance=$1
    tnsping=/opt/app/oracle/product/11.2.0/client_1/bin/tnsping
    var1=$($tnsping $instance)
    var2=$(echo $var1 |grep -Eoh '[0-9]* msec' |grep -Eoh '*[0-9]*')
    echo $var2
    In zabbix agent I set it up:
    UserParameter=tnsping[*],/opt/scripts/pingOracle.sh $1
    If I run /sbin/zabbix_agentd -t tnsping[ORACLE1]
    I get
    tnsping[ORACLE1]  [t|15240]
    But from zabbix server running zabbix_get -s servername -k tnsping[ORACLE1] I get a empty response.
    TImeout in zabbix server and agent is 30.
    Click image for larger version  Name:	Capturar.PNG Views:	1 Size:	4.9 KB ID:	359468
    Zabbix agent log
      1681:20180530:104959.716 Requested [tnsping[ORACLE1]]
      1681:20180530:104959.716 In zbx_popen() command:'/opt/scripts/pingOracle.sh ORACLE1'
      1681:20180530:104959.716 End of zbx_popen():7
      1713:20180530:104959.716 zbx_popen(): executing script
      1681:20180530:104959.728 In zbx_waitpid()
      1681:20180530:104959.728 zbx_waitpid() exited, status:0
      1681:20180530:104959.728 End of zbx_waitpid():1713
      1681:20180530:104959.728 EXECUTE_STR() command:'/opt/scripts/pingOracle.sh ORACLE1' len:0 cmd_result:''
      1681:20180530:104959.728 Sending back []
  • Atsushi
    • Aug 2013
    • 2028
    Even if the Timeout setting is extended to 30 seconds, processing that takes more time can not be acquired with UserParameter.
    For example, please periodically run it with cron etc., output it to a file, and specify UserParameter to get only the result value from that file.
    • akbar415
      • May 2015
      • 119
      I timed the comand (/sbin/zabbix_agentd -t tnsping[ORACLE1]) and take 10 seconds, in the worst case, to receive a empty answer, futhermore when is Timeout problem zabbix show the message "timeout while executing a shell script".
      • aib
        • Jan 2014
        • 1615
        Sometimes zabbix_agent cannot provide information to zabbix_server because of not sufficient permissions to start scripts/processes. Change log level to debug on agent side, restart agent, and repeat zabbix_get command on server side. Then check zabbix_agent.log file to be sure that there are no error messages.
        Sincerely yours,
        Aleksey
        • akbar415
          • May 2015
          • 119
          I update my question with the log in debug mode.
          • aib
            • Jan 2014
            • 1615
            Do you have any chance to log the execution of TNSPING? From your debug log I assume that tnsping did not start or throw an error message which was filtered out by pipe of grep's
            One more option, do you mind temporarily change pingOracle script? For example, change "echo $var2" to "echo $var1" to see the full message from tnsping...
            Sincerely yours,
            Aleksey
