Create new Low Free Disk tigger error
  • ascholte
    • Jan 2014
    Hi.
    I have two Low Free Disk triggers for our C and D drives. They work fine. I've tried to clone the trigger and create it for E or F drives. But I get a cannot add trigger error. Is it possible to create the trigger for other drives then C or D ?
    Thank you.
  • johansen
    • Oct 2009
    • 38
    sure, but you have to create the items first before you can add triggers.
    So basically clone item for C: and D: drives and then to the same for the triggers.
    • ascholte
      • Jan 2014
      thank you Johansen, worked perfectly
