Active checks host not found
  • felix.citycs
    • Jun 2018
    Hi guys,
    I am new to Zabbix ... please forgive if my question is similar to others but I have tired different way but still not solving it..
    Here are my setting:
    Server 1: zabbix server & zabbix agent
    IP: 172.31.11.194
    ubuntu@ip-172-31-11-194:~$ hostname
    ip-172-31-11-194
    Server 1: /usr/share/zabbix/conf/zabbix.conf.php
    <?php
    // Zabbix GUI configuration file.
    global $DB;
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = 'localhost';
    $DB['PORT'] = '0';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER'] = '[username]';
    $DB['PASSWORD'] = '[password]';
    // Schema name. Used for IBM DB2 and PostgreSQL.
    $DB['SCHEMA'] = '';
    $ZBX_SERVER = '172.31.11.194';
    $ZBX_SERVER_PORT = '10051';
    $ZBX_SERVER_NAME = 'ip-172-31-11-194';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    Server 1: /etc/zabbix/zabbix_server.conf
    DBHost=localhost
    DBUser=[username]
    DBPassword=[password]
    Server 1: /etc/zabbix/zabbix_agentd.conf
    Server=172.31.11.194
    ServerActive=172.31.11.194:10051
    Hostname=172.31.11.194
    Server 2: zabbix agent
    IP: 172.31.6.97
    ubuntu@ip-172-31-6-97:~$ hostname
    ip-172-31-6-97
    Server 2: /etc/zabbix/zabbix_agentd.conf
    Server 3: zabbix agent
    IP: 172.31.12.68
    ubuntu@ip-172-31-12-68:~$ hostname
    ip-172-31-12-68
    Server 3: /etc/zabbix/zabbix_agentd.conf
    And here are the logs returning..
    Server 1: /var/log/zabbix/zabbix_server.log
    16574:20180604:032106.488 cannot send list of active checks to "172.31.6.97": host [172.31.11.194] not found
    16574:20180604:032121.554 cannot send list of active checks to "172.31.12.68": host [172.31.11.194] not found
    16574:20180604:032129.299 cannot send list of active checks to "172.31.11.194": host [172.31.11.194] not found
    16574:20180604:032306.637 cannot send list of active checks to "172.31.6.97": host [172.31.11.194] not found
    16574:20180604:032321.578 cannot send list of active checks to "172.31.12.68": host [172.31.11.194] not found
    16572:20180604:032329.324 cannot send list of active checks to "172.31.11.194": host [172.31.11.194] not found
    16574:20180604:032506.660 cannot send list of active checks to "172.31.6.97": host [172.31.11.194] not found
    16577:20180604:032521.602 cannot send list of active checks to "172.31.12.68": host [172.31.11.194] not found
    16577:20180604:032529.347 cannot send list of active checks to "172.31.11.194": host [172.31.11.194] not found
    Server 1: /var/log/zabbix/zabbix_agentd.log
    16748:20180604:031929.275 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    16748:20180604:032129.299 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    16748:20180604:032329.324 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    Server 2: /var/log/zabbix/zabbix_agentd.log
    17064:20180604:031906.457 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    17064:20180604:032106.481 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    17064:20180604:032306.632 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    Server 3: /var/log/zabbix/zabbix_agentd.log
    14006:20180604:031921.516 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    14006:20180604:032121.538 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    14006:20180604:032321.562 no active checks on server [172.31.11.194:10051]: host [172.31.11.194] not found
    Basically I have tried also changing the $ZBX_SERVER to OS hostname (i.e. ip-172-31-11-194), and corresponding Hostname parameter in zabbix_agentd.log. After restarting both zabbix server and all agents, the problem is still there...
    I think I got lost somewhere setting the hostname in zabbix.. can you guys advise me how to fix it? Thank you very much.
  • Atsushi
    • Aug 2013
    • 2028
    The setting of Hostname in zabbix_agentd.conf on each server is incorrect without Server 1.
    Hostname does not specify the name corresponding to the host of the Zabbix server.
    Specify the name of the host itself that starts the Zabbix agent.
    And the name you specified for Hostname in zabbix_agentd.conf must be registered as a host on the Web frontend on the Zabbix server.
    • felix.citycs
      • Jun 2018
      Hi Atsushi,
      I find out the Hostname parameter in zabbix agent should be same as the "Hostname" in "Host" page on the Zabbix Web GUI.
