We have a custom zabbix_sender that sends some database statistics through an IPSEC VPN to our zabbix server.
The data doesn't get accepted and I see loads of these messages in the log:
Message size 7309943056852058316 from xxx.xxx.xxx.xxx exceeds the maximum size 67108864 bytes. Message ignored
When i sniff the traffic with tcpdump and send the exact same data directly using netcat (nc) on the port, it gets accepted perfectly.
After searching a lot I read some info about MTU issues that can cause these issues.
So I lowered the MTU to 1472 and forced MSS clamping:
http://lartc.org/howto/lartc.cookbook.mtu-mss.html
But I still get the errors. Any tips?
Kind regards,
Jorick Astrego
Netbulae B.V.
Kind regards,
Jorick Astrego
Netbulae B.V.
