I got the above message every few hours on the dashboard and error will be disappeared after putty in and restart the zabbix-server service.
When the above error happened again, I check on zabbix status (/etc/init.d/zabbix-server status) and discovered an inactive (dead) at the 2nd line below.
zabbix-server.service - Zabbix Server
Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mon 2018-06-04 18:57:33 SGT; 15h ago
Process: 22545 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=0/SUCCESS)
Process: 1144 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
Main PID: 1293 (code=exited, status=0/SUCCESS)
Hence, i also checked on zabbix_serverlog, and seeing a lot the "of type "string" is not suitable for value type "Numeric (unsigned)". And always happened after zabbix-server being restarted.
A few hour later, the above message appeared again.
23029:20180605:230422.136 server #54 started [preprocessing worker #1]
23030:20180605:230422.137 server #55 started [preprocessing worker #2]
23031:20180605:230422.137 server #56 started [preprocessing worker #3]
22980:20180605:230424.928 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "48.298233" of type "string" is not suitable for value type "Numeric (unsigned)"
22982:20180605:230429.957 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "56.798033" of type "string" is not suitable for value type "Numeric (unsigned)"
22980:20180605:230438.019 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "43.981353" of type "string" is not suitable for value type "Numeric (unsigned)"
22983:20180605:230446.096 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "61.435125" of type "string" is not suitable for value type "Numeric (unsigned)"
22981:20180605:230453.136 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "25.065630" of type "string" is not suitable for value type "Numeric (unsigned)"
22982:20180605:230455.137 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "48.524354" of type "string" is not suitable for value type "Numeric (unsigned)"
22983:20180605:230457.157 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "80.979523" of type "string" is not suitable for value type "Numeric (unsigned)"
22981:20180605:230458.162 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "57.087273" of type "string" is not suitable for value type "Numeric (unsigned)"
22981:20180605:230459.170 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "56.797972" of type "string" is not suitable for value type "Numeric (unsigned)"
22980:20180605:230503.233 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "77.858487" of type "string" is not suitable for value type "Numeric (unsigned)"
22999:20180605:230516.633 cannot send list of active checks to "127.0.0.1": host [UbuntuZabbix] not found
22983:20180605:230522.351 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "48.299276" of type "string" is not suitable for value type "Numeric (unsigned)"
22983:20180605:230528.373 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "65.145471" of type "string" is not suitable for value type "Numeric (unsigned)"
22983:20180605:230529.377 error reason for "servername:vfs.fs.size[c:,pfree]" changed: Value "85.759859" of type "string" is not suitable for value type "Numeric (unsigned)"
Please help on this issue as I am not familiar with Zabbix system. Thank you
