zabbix proxy on beaglebone
  • victorfrankl
    • Jun 2018
    Hi all,
    I have installed the debian stretch image on my beaglebone. After the standard dependencie hell, i have zabbix proxy and mysql running.
    DB is created and i have to zcat the db schema.
    Problem is the /usr/share/doc/zabbix-proxy-mysql folder does not contain the scheme file.
    Is there anyone who can tell why that is? and where i can get the right scheme file?
    Oh and any suggestions to create cheaper proxies? The beaglebone black is around 80 euro with case. When done setting it up on the sd card i'll flsh it to the internal 2GB emm flash. Is 2GB enough for a zabbix proxy?
  • Colttt
    • Mar 2009
    • 878
    which reposetory do you use? and a cheaper one will be a RaspberryPi, BananaPi oder Cubieboard.
    Debian-User
    Sorry for my bad english
    • kernbug
      • Feb 2013
      • 329
      Originally posted by victorfrankl
      Hi all,
      Hi
      You can get schema.sql from sources https://www.zabbix.com/download_sources
      Raspberry PI 3 + 2 Gb MicroSD for OS and Zabbix Proxy with SQLite3 in 384-512mb tmpfs in ram will be cheaper and up to 500 nvps. Network performance of such micro pc mostly poor.
