Hi, Im having problems to upgrade my server.
CentOS 6.5
dependencies OK, no erros after ./configure or make install
when I start the server:
Sugestions? table proxy_autoreg_host already OK witht the Ip type...
CentOS 6.5
./configure --prefix=/opt/zabbix --mandir=/usr/share/man --enable-server --disable-static --disable-proxy --enable-agent --enable-ipv6 --with-postgresql --with-libcurl --with-net-snmp --with-ssh2 --with-openipmi --with-libxml2 --with-unixodbc
[---@--- tmp]# /etc/init.d/zabbix_server start Starting zabbix_server: [ OK ] [---@--- tmp]# tail -f zabbix_server.log 12455:20140124:105309.237 SSH2 support: YES 12455:20140124:105309.237 IPv6 support: YES 12455:20140124:105309.237 ****************************** 12455:20140124:105309.237 using configuration file: /opt/zabbix/etc/zabbix_server.conf 12455:20140124:105309.247 current database version (mandatory/optional): 02010000/02010000 12455:20140124:105309.247 required mandatory version: 02020000 12455:20140124:105309.248 starting automatic database upgrade 12455:20140124:105309.248 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERRO: must be the owner of relation proxy_autoreg_host [alter table proxy_autoreg_host alter id type bigint] 12455:20140124:105309.248 database upgrade failed
