Zabbix Servers behind HAProxy
  • eset
    • Jun 2018
    • 9
    Found some subjects here but there aren't lot of discuss about that so maybe I will raised the subject : Zabbix Servers behind HAproxy in Active/Passive mode
    If I may I will just leave the link to Stackoverflow where I described my problem: https://stackoverflow.com/questions/...behind-haproxy
  • kernbug
    • Feb 2013
    • 329
    Hello
    Zabbix Server/Zabbix Proxy are stateless, you can run another instance in case of crash immediately.
    Example of the more reliable schema:
    In this tutorial we will cover how to set up high availability Zabbix server. We are going to create a HA Active/Passive Cluster that consists of two CentOS7 / RHEL7
    • eset
      eset commented
      Ok But I'm using different approach for more flexible redundancy.
      I manage to solve that. Missing:
      mode tcp
      in Backend section of haproxy.cfg.
      But I have another question. When adding zabbix-agents to zabbix-server itself to monitor also those servers how to added them on frontend? How are the recognized? I'm sure not by 'Zabbix Server' name?
  • kernbug
    • Feb 2013
    • 329
    By default host interface of the Zabbix Server is 127.0.0.1 and name "Zabbix server". You can choose any name and set it up in the Web Frontend and Zabbix Agent "hostname=". IP address also could be from main network interface, not only from loopback.
    • eset
      • Jun 2018
      • 9
      could be ? So I can add Server= and ServerActive as 127.0.0.1,10.x.x.x ?
      • kernbug
        • Feb 2013
        • 329
        Why not? Local to the server Zabbix Agent will work.
        • eset
          • Jun 2018
          • 9
          Ok I'm asking because in zabbix_server.log I've got a lots of entries like this:
          sudo tail -f /var/log/zabbix/zabbix_server.log
           11990:20180618:130038.934 [Z3005] query failed: [1062] Duplicate entry '28538-1529316000' for key 'PRIMARY' [insert into trends_uint (itemid,clock,num,value_min,value_avg,value_max) values (28538,1529316000,60,1529316038,1529317808,1529319578),(28658,1529316000,60,0,0,1),(28718,1529316000,60,3776,17368,28616);
           11990:20180618:130040.045 [Z3005] query failed: [1062] Duplicate entry '28599-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28599,1529316000,60,0.000000,0.000000,0.000000);
           11988:20180618:130041.121 [Z3005] query failed: [1062] Duplicate entry '28600-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28600,1529316000,60,0.000000,0.000565,0.016946),(28540,1529316000,60,100.000000,100.000000,100.000000),(28720,1529316000,60,89.032898,89.032972,89.033203);
           11990:20180618:130058.874 [Z3005] query failed: [1062] Duplicate entry '28618-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28618,1529316000,60,99.593544,99.594612,99.619675);
           11990:20180618:130059.970 [Z3005] query failed: [1062] Duplicate entry '28619-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28619,1529316000,60,2.294561,2.328483,2.542593);
           11987:20180618:130523.996 [Z3005] query failed: [1062] Duplicate entry '28523-1529316000' for key 'PRIMARY' [insert into trends_uint (itemid,clock,num,value_min,value_avg,value_max) values (28523,1529316000,6,1529005764,1529005764,1529005764);
          and on second zabbix-server
            2648:20180618:130055.568 [Z3005] query failed: [1062] Duplicate entry '28614-1529316000' for key 'PRIMARY' [insert into trends_uint (itemid,clock,num,value_min,value_avg,value_max) values (28614,1529316000,60,0,0,0);
            2648:20180618:130055.623 [Z3005] query failed: [1062] Duplicate entry '28555-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28555,1529316000,60,0.000000,0.015979,0.958740);
            2648:20180618:130056.684 [Z3005] query failed: [1062] Duplicate entry '28616-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28616,1529316000,60,99.999094,99.999974,100.000000),(28556,1529316000,60,0.287211,0.349100,0.497427);
            2648:20180618:130057.775 [Z3005] query failed: [1062] Duplicate entry '28617-1529316000' for key 'PRIMARY' [insert into trends (itemid,clock,num,value_min,value_avg,value_max) values (28617,1529316000,60,99.775293,99.779178,99.779489),(28557,1529316000,60,0.000000,0.000565,0.016946);
            2643:20180618:130222.173 executing housekeeper
            2643:20180618:130222.733 housekeeper [deleted 0 hist/trends, 0 items/triggers, 0 events, 0 problems, 0 sessions, 0 alarms, 0 audit items in 0.085167 sec, idle for 1 hour(s)]
          It looks like the same zabbix-server entries have been duplicated.
          Ok I cleared configuration on front , probably those entries above where because I add those zabbix application server wrong.
          So on both zabbix applications servers (zabbix server) I added on zabbix_agent.conf:
          monit-app-01 (10.156.0.10)
          Server=127.0.0.1,10.156.0.10
          ServerActive=127.0.0.1,10.156.0.10
          monit-app-02 (10.164.0.10)
          Server=127.0.0.1,10.164.0.10
          ServerActive=127.0.0.1,10.164.0.10
          How about when adding a node to zabbix-server so in zabbix_agentd.conf I should add it like this?
          Server=172.31.255.254,10.156.0.10,10.164.0.10
          ServerActive=172.31.255.254,10.156.0.10,10.164.0.10
          from the left are in sequence: Floating IP, monit-app-01, monit-app-02
          So it's not working properly:
          On monit-app-01 I get:
           15490:20180618:134120.265 failed to accept an incoming connection: connection from "10.164.0.10" rejected, allowed hosts: "127.0.0.1,10.156.0.10"
          where 10.164.0.10 is monit-app-02 strange.
          On monit-app-02 I get:
            8958:20180618:134233.790 failed to accept an incoming connection: connection from "10.156.0.10" rejected, allowed hosts: "127.0.0.1,10.164.0.10"
          where 10.156.0.10 is 10.156.0.10
          • eset
            • Jun 2018
            • 9
            When adding on front two zabbix servers into Configuration / Hosts with their local IP addresses I get
            Zabbix agent on monit-app-01 is unreachable for 5 minutes
            • kernbug
              • Feb 2013
              • 329
              Zabbix Agent configuration parameters:
              "ServerActive" -> outgoing connection to server -> Zabbix Server
              "Server" <- incoming connection from server <- Zabbix Server
              you need
              Server=10.164.0.10,10.156.0.10 #(incoming passive checks)
              ServerActive=10.164.0.10,10.156.0.10 #(outgoing active checks)
              in frontend:
              • eset
                • Jun 2018
                • 9
                Yeah ok I've added it like that and it works on. I mean the zabbix-agents on zabbix-servers. But other nodes added directly to Zabbix Servers (without proxy) should have this:
                 Server=172.31.255.254,10.156.0.10,10.164.0.10 ServerActive=172.31.255.254,10.156.0.10,10.164.0.10
                172.31.255.254 is floating IP so basically for all agents (directly connected) and proxy's it should be like that?
                • eset
                  • Jun 2018
                  • 9
                  Ok but Are you sure this is correct? I added it so and now, Zabbix Bot send notifications twice
                  Problem: PROBLEM:monit-app-02:Zabbix agent on monit-app-02 is unreachable for 5 minutes
                  Host: monit-app-02
                  Trigger: PROBLEM: Zabbix agent on monit-app-02 is unreachable for 5 minutes: High
                  Timestamp: 2018.06.18 22:42:00
                  Eventid: 367
                  this is from monit-app-01
                  root@monit-app-01:/usr/lib/zabbix/alertscripts# tail -f /var/log/zabbix/zabbix_server.log |grep -i --color slack
                   29140:20180618:224202.295 In substitute_simple_macros() data:'--slack'
                  Eventid: 367' '--api_token=xxxx' '--slack''
                  Eventid: 367' '--api_token=xxxx' '--slack' output:
                  on slack I see something like this
                  monit-app-01 ID:369
                  but there is also a second event I receive is with ID 369 from monit-app-02
                  monit-app-02 ID:369
                  and on frontend I see this
                  It's duplicated
                  kernburg
                  I think you are wrong about ServerActive. If Zabbix node with Zabbix-agent needs to retrieve information it only needs to retrieve from one (active - behind HAProxy or active on Floating IP) zabbix-server not both like you proposed. So in ServerActive=<FLOATING_IP_or_HAProxy_IP> where those two zabbix-server stands behind. And Server= I agree it has incoming connections so both zabbix-server IP addresses needs to be there because their aren't SRC-NATed through HAProxy or FLOATING_IP that's why incoming connection comes from specific (active at the time it comes) server so It needs to be listed there for access.
                  • kernbug
                    • Feb 2013
                    • 329
                    Hi, sorry, but I don't know about your exact setup, so ServerActive= of course should contain Virtual IP. It was my example suggestion.
                    • eset
                      • Jun 2018
                      • 9
                      I gave you my exact setup. Server and ServerActive these are the most important things.
                      Ok I managed to set keepalive and floating ip. Two zabbix-server works, one is active second is deactivated (active only if the primary server goes down).
                      I set also zabbix-proxy server, added in zabbix_proxy.conf
                      Server=10.156.0.10,10.164.0.10
                      those IP addresses are the zabbix servers addresses (first is active, second deactivated).
                      On zabbix-agents nodes I've set IP address of zabbix-proxy node. Example of zabbix_agentd.conf:
                      Server=10.5.0.149
                      ServerActive=10.5.0.149
                      but that doesn't work. Example host: samariumhas the following error:
                       17922:20180626:230607.241 no active checks on server [10.5.0.149:10051]: host [samarium] not found
                       17922:20180626:230807.291 no active checks on server [10.5.0.149:10051]: host [samarium] not found
                       17922:20180626:231007.346 no active checks on server [10.5.0.149:10051]: host [samarium] not found
                       17922:20180626:231207.397 no active checks on server [10.5.0.149:10051]: host [samarium] not found
                      and in zabbix-proxy
                        8072:20180626:230341.062 trapper got '{"request":"active checks","host":"samarium","host_metadata":"Linux UpCloud"}'
                        8072:20180626:230341.062 In get_hostid_by_host() host:'samarium'
                        8072:20180626:230341.062 query [txnlev:0] [select hostid,status,tls_accept,tls_issuer,tls_subject,tls_psk_identity from hosts where host='samarium' and status in (0,1) and flags<>2 and proxy_hostid is null]
                        8072:20180626:230341.063 query [txnlev:1] [insert into proxy_autoreg_host (clock,host,listen_ip,listen_dns,listen_port,host_metadata) values (1530047021,'samarium','10.2.2.116','samarium',10050,'Linux UpCloud')]
                        8072:20180626:230341.064 cannot send list of active checks to "10.2.2.116": host [samarium] not found
                        8072:20180626:230341.064 send_list_of_active_checks_json() sending [{"response":"failed","info":"host [samarium] not found"}]
                      I changed in zabbix_proxy.conf
                      Server=10.156.0.10,10.164.0.10 => Server=172.31.255.254
                      Now server, those behind zabbix-proxy are correctly added using auto-registration but on Configuration / Hosts the ZBX isn't green on those hosts which indicates that zabbix-agent isn't reachable.
                      Logs on zabbix-proxy say:
                       11091:20180627:000643.912 In connect_to_server() [172.31.255.254]:10051 [timeout:600]
                       11091:20180627:000645.031 In connect_to_server() [172.31.255.254]:10051 [timeout:600]
                       11091:20180627:000646.137 In connect_to_server() [172.31.255.254]:10051 [timeout:600]
                      • kernbug
                        • Feb 2013
                        • 329
                        Hi
                        If one server is deactivated, you primary IP is 'floating IP', for 'Server' and 'ServerActive' of the Agents and Proxies configuration file.
                        And this is correct in this case.
                        ZBX icon stay green if host has passive checks.
                        From Zabbix Proxy check up port 10051, it should be opened on the Zabbix Server for your Zabbix Proxy:
                        telnet 172.31.255.254 10051
                        or
                        ##netcat utility
                        nc -vz 172.31.255.254 10051
                        • eset
                          • Jun 2018
                          • 9
                          Hi
                          True but only if zabbix-server is on that IP
                          SourceIP & ListenIP
                          I nedd that also to work and are you sure ? I can change item type for zabbix agent template to Zabbix Agent (Active) then this is checked by zabbix-agent not by zabbix-server
                          or
                          ##netcat utility
                          Checking connection from proxy -> zabbx
                          nmap 172.31.255.254 -Pn -p 10051
                          Starting Nmap 7.40 ( https://nmap.org ) at 2018-06-27 11:32 CEST
                          Nmap scan report for 172.31.255.254
                          Host is up (0.025s latency).
                          PORT      STATE SERVICE
                          10051/tcp open  zabbix-trapper
                          Trying 172.31.255.254...
                          Connected to 172.31.255.254.
                          Escape character is '^]'.
                          Connection closed by foreign host
                          172.31.255.254: inverse host lookup failed: Unknown host
                          (UNKNOWN) [172.31.255.254] 10051 (zabbix-trapper) open
                          • eset
                            • Jun 2018
                            • 9
                            #15
                            I changed Type in Items from Zabbix Agent to -> Zabbix Agent (active) and it worked almost for all templates.
