{HOST.NAME} macro in trigger name
  • rmartineau
    • Jan 2014
    On version 1.8 it was possible to add the {HOSTNAME} macro in the name of a trigger, which should also be the case in v2.2 according to the manual, but with the {HOST.NAME} macro.
    Unfortunately for me it does not work on version 2.2 that I just installed.
    is this a known bug or have I missed to do something?
    Thank you in advance
  • JvGinkel
    • Jan 2014
    • 10
    I can second that, I have the same problems with our 2.2.1 installation. It was upgraded from 2.0.10 to 2.2.1 (RHEL 6) and while the checks work (with {HOSTNAME}, {HOST.NAME} and {HOST.HOST}) are succesful (which I see in the Latest Data), the variables are not substitued in the name.
