VFS.FS.SIZE strange behaviour
  • stewie83
    • Oct 2013
    • 9
    I'm running zabbix 3.4.8 (both on server and proxy) and I'm experiencing a very strange behaviour. I've a server running Ubuntu Vivid that is not returning correct value for some fuse filesystem. From the web interface i always see 0B as total, used, pfree, free which is obviously false. I've tried to query the agent both with zabbix_agentd and zabbix_get and this is the result:
    zabbix_agentd from the monitored host:
    zabbix_agentd -t vfs.fs.size[/srv/dd_rm/imm_log,total]
    vfs.fs.size[/srv/dd_rm/imm_log,total] [u|138588670918656] (Correct, is 127TB)
    zabbix_get from the zabbix proxy:
    zabbix_get -s HOSTNAME -p 10050 -k "vfs.fs.size[/srv/dd_rm/imm_log,total]"
    0 (Wrong)
    Do you have any advice? I've tried almost everything, no more ideas... Maybe a limitation of the filesystem size monitored by Zabbix?
  • kernbug
    • Feb 2013
    • 329
    0 (Wrong)
    Hi
    Plea, show from Ubuntu Vivid:
    mount
    ls -la /srv/dd_rm/
    cat /etc/fstab
    • stewie83
      • Oct 2013
      • 9
      Originally posted by kernbug
      Hi
      mount
      cat /etc/fstab
      (Only relevant part)
      xxx:/imm_altro /srv/dd_rm/imm_altro boostfs _netdev 0 0
      xxx:/imm_log /srv/dd_rm/imm_log boostfs _netdev 0 0
      xxx:/imm_db /srv/dd_rm/imm_db boostfs _netdev 0 0
      mount
      boostfs on /srv/dd_rm/imm_log type fuse.boostfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
      boostfs on /srv/dd_rm/imm_altro type fuse.boostfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
      boostfs on /srv/dd_rm/imm_db type fuse.boostfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
      ls -la /srv/dd_rm/
      drwxrwxrwx  6  500 users  420 Jun 15 09:05 imm_altro
      drwxrwxrwx 10  500 users  543 Jun  8 08:37 imm_db
      drwxrwxrwx  7  500 users  405 Mar 16 15:26 imm_log
      cat /etc/fstab
      • kernbug
        • Feb 2013
        • 329
        mount
        Only for test purposes run Zabbix Agent as root, to be sure this is permission problems or not.
        • stewie83
          • Oct 2013
          • 9
          You're definitely right. It was a permission's problem because they are mounted with Fuse. Thank's you very much.
