The frontend does not match Zabbix database.
  • sphtd
    • Jun 2018
    Hi Everonyone! Im trying to install zabbix but i got a problem..
    Cannot connect to the database.
    The frontend does not match Zabbix database. Current database version (mandatory/optional): 3000000/3000000. Required mandatory version: 3040000. Contact your system administrator.
    I do not know what to do now :/
  • kernbug
    • Feb 2013
    • 329
    Hi
    Upgrade Zabbix Server with DB or downgrade Zabbix Web Frontend version.
    • zippo
      • Jun 2018
      • 9
      Hello!
      Аaced the same problem. As a result, it turned out that the interface was installed not from packages, but by downloading the archive and transferring it to the directory / var / www / zabbix. Accordingly, I downloaded from the repository a package of .deb for ubuntu, unzipped and moved to the correct directory.
