Zabbix false alarms
  • fsousa
    • Aug 2017
    • 99
    Zabbix false alarms
    I'm using the Zabbix Server version 3.4.1. I've facing some troubles with my server.
    I'm receive too many false alerts, I know the alarms are false because when I receive the alert from specific host if I run the zabbix_get command in the server to that host, it responds.
    The error I got: "Zabbix agent on sp3.cbr.srv is unreachable for 5 minutes"
    Have you ever had this problem?
    Any help would really be appreciated.
    Thank you.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Make sure you have good connection between the server and the agent. By default connection timeout is 3 seconds. See how much time takes zabbix_get when run from Zabbix server host:
    $ time zabbix_get -s <agent IP> -p <agent port> -k system.uptime
    1139851
    real    0m0.004s
    user    0m0.000s
    sys     0m0.000s
    It is important to run this command from Zabbix server host.
    P. S. It's time to upgrade, 3.4.11 was out recently. :-)
    • fsousa
      • Aug 2017
      • 99
      Hello @dimir,
      Thank you for your reply.
      My time when I run the command time zabbix_get are:
      [root@zabbix ~]# time zabbix_get -s webgw.cbr.srv.wit -p 10050 -k system.uptime
      17279044
      real 0m0.009s
      user 0m0.001s
      sys 0m0.004s
      P.S. Shortly I will upgrade my server to the latest version.
