Undefined offset: 35 [httpdetails.php:82 → CScreenHttpTestDetails->get()
  • tolland
    • Apr 2008
    • 20
    Update: this issue arises when creating and adding Web Scenarios to Templates, and applying them to hosts using the API. Currently it appears that adding a Web Scenario to a Template, doesn't automatically propagate that to the linked hosts.
    (systems details are pasted in at the end of the post - however both zabbix and the agent are running version 3.4.10-1.el7 with MySQL backend)
    I've added some Web Monitors and their triggers to a Template called "Web Checks" using the API, and added this template to my main zabbix server "zabbix". However when trying to view this in "Monitoring -> Web" I am seeing PHP errors in the output.... The error seems to be related to when the httpdetails.php screen attempts to call getMinClock() in CHistoryManager.php
    I am seeing this error on the Monitoring-Web screen...
    Click image for larger version  Name:	Screenshot_2018-06-30_22-31-14.png Views:	2 Size:	85.5 KB ID:	361572
    Initially the page seems to return ok, but after a few minutes, the error appears and stays there.
    Undefined offset: 35 [httpdetails.php:82 → CScreenHttpTestDetails->get() in
                                include/classes/screens/CScreenHttpTestDetails.php:99]
    Invalid argument supplied for foreach() [httpdetails.php:82 →
                                      CScreenHttpTestDetails->get() in include/classes/screens/CScreenHttpTestDetails.php:122]
    min(): Array must contain at least one element [httpdetails.php:121 →
                          CHistoryManager->getMinClock() → min() in include/classes/api/managers/CHistoryManager.php:728
    The template for the web monitoring looks like this
    HTML Code:
    <?xml version="1.0" encoding="UTF-8"?>
    <zabbix_export>
    <version>3.4</version>
    <date>2018-06-30T21:33:42Z</date>
    <groups>
    <group>
    <name>Templates</name>
    </group>
    <group>
    <name>Web Checks</name>
    </group>
    </groups>
    <templates>
    <template>
    <template>Web Checks</template>
    <description/>
    <groups>
    <group>
    </group>
    <group>
    </group>
    </groups>
    <applications/>
    <items/>
    <discovery_rules/>
    <httptests>
    <httptest>
    <name>somesite.com</name>
    <application/>
    <delay>1m</delay>
    <attempts>1</attempts>
    <agent>Zabbix</agent>
    <http_proxy/>
    <variables/>
    <headers/>
    <status>0</status>
    <authentication>0</authentication>
    <http_user/>
    <http_password/>
    <verify_peer>0</verify_peer>
    <verify_host>0</verify_host>
    <ssl_cert_file/>
    <ssl_key_file/>
    <ssl_key_password/>
    <steps>
    <step>
    <name>somesite.com-1</name>
    <url>http://somesite.com</url>
    <query_fields/>
    <posts/>
    <variables/>
    <headers/>
    <follow_redirects>1</follow_redirects>
    <retrieve_mode>0</retrieve_mode>
    <timeout>15s</timeout>
    <required/>
    <status_codes/>
    </step>
    </steps>
    </httptest>
    </httptests>
    <macros/>
    <templates/>
    <screens/>
    </template>
    </templates>
    <triggers>
    <trigger>
    <expression>{Web Checks:web.test.error[somesite.com].strlen()}&gt;0</expression>
    <recovery_mode>0</recovery_mode>
    <recovery_expression/>
    <name>Web scenario &quot;Scenario&quot; failed: {ITEM.VALUE} (alt)</name>
    <correlation_mode>0</correlation_mode>
    <correlation_tag/>
    <url/>
    <status>0</status>
    <priority>3</priority>
    <description/>
    <type>0</type>
    <manual_close>0</manual_close>
    <dependencies/>
    <tags/>
    </trigger>
    </triggers>
    </zabbix_export>
    Background
    Running zabbix packages from the draios repos;
    # cat /etc/yum.repos.d/draios.repo.repo
    [draios]
    baseurl = http://download.draios.com/stable/rpm/$basearch
    enabled = 1
    gpgcheck = 1
    name = Draios
    Packages are updated...
    [root@zabbix ~]# rpm -qa | grep zabbix
    zabbix-web-mysql-3.4.10-1.el7.noarch
    zabbix-get-3.4.10-1.el7.x86_64
    zabbix-agent-3.4.10-1.el7.x86_64
    zabbix-web-3.4.10-1.el7.noarch
    zabbix-server-mysql-3.4.10-1.el7.x86_64
    zabbix-sender-3.4.10-1.el7.x86_64
    System is CentOS 7.5
    [root@zabbix ~]# cat /etc/redhat-release
    CentOS Linux release 7.5.1804 (Core)
  • tolland
    • Apr 2008
    • 20
    So examining the code from the error in
    /usr/share/zabbix/include/classes/api/managers/CHistoryManager.php
    at line 728
    it looks like neither of these 2 are returning anything;
    PHP Code:
    $min_clock = [];
    if (
    array_key_exists(ZBX_HISTORY_SOURCE_ELASTIC, $storage_items)) {
    $min_clock[] = $this->getMinClockFromElasticsearch($storage_items[ZBX_HISTORY_SOURCE_ELASTIC]);
    if (
    array_key_exists(ZBX_HISTORY_SOURCE_SQL, $storage_items)) {
    $min_clock[] = $this->getMinClockFromSql($storage_items[ZBX_HISTORY_SOURCE_SQL], $source);
    $min_clock = min($min_clock);
    presumably this one should be getting something....
    PHP Code:
    if (array_key_exists(ZBX_HISTORY_SOURCE_SQL, $storage_items)) {
    from debugging, I can see that $storage_items is empty, because $item_types is an array of empty arrays;
    PHP Code:
    foreach ($item_types as $type => $itemids) {
    error(_s('type is: %1$s.', str_replace("\n",' ',print_r($type, true))));
    error(_s('itemids is: %1$s.', str_replace("\n",' ',print_r($itemids, true))));
    if (!
    $itemids) {
         continue;
    $history_source = self::getDataSourceType($type);
    $storage_items[$history_source][$type] = $itemids;
    returns;
    type is: 0.
    itemids is: Array ( ) .
    type is: 1.
    type is: 2.
    type is: 3.
    type is: 4.
    storage types is: Array ()
    So it looks like that $item_types is setup wrong somehow
    ... further debugging shows that
    PHP Code:
        public function getMinClock(array $items) {
    error(_s('item count is: %1$s.', str_replace("\n",' ',print_r(count ($items), true))));
    outputs...
    • item count is: 0.
    the $items array passed in is empty....
    • kloczek
      • Jun 2006
      • 1771
      You did not provide:
      - details in what kind scenario are those errors
      - used version of the zabbix
      - in which file you see fragment of the code
      • tolland
        • Apr 2008
        • 20
        Thanks. Apologies, I had been watched the football, and had a few beers, so I wasn't thinking straight when I made the first post.. :-)
        I added the details and some more debugging...
        • tolland
          • Apr 2008
          • 20
          So it looks like public function getMinClock(array $items) is call from line 121 in httpdetails.php
          PHP Code:
          $graph_in->timeline['starttime'] = date(TIMESTAMP_FORMAT, Manager::History()->getMinClock($items));
          dumping out the query that generates the $items array gives this;
          PHP Code:
          $items = DBfetchArray(DBselect(
          'SELECT i.itemid,i.value_type,i.history,i.trends,i.hostid'.
          ' FROM items i,httpstepitem hi,httpstep hs'.
          ' WHERE i.itemid=hi.itemid'.
          ' AND hi.httpstepid=hs.httpstepid'.
          ' AND hs.httptestid='.zbx_dbstr($httptest['httptestid'])
          SELECT
              i.itemid,
              i.value_type,
              i.history,
              i.trends,
              i.hostid
          FROM
              items i,
              httpstepitem hi,
              httpstep hs
          WHERE
              i.itemid=hi.itemid
          AND hs.httptestid='20'
          which returns no results in the databases;
          Empty result set fetched
          So I deleted all the checks except one, and then dumped out all the web checks;
          SELECT
              i.itemid,
              i.value_type,
              i.history,
              i.trends,
              i.hostid
          FROM
              items i,
              httpstepitem hi,
              httpstep hs
          WHERE
              i.itemid=hi.itemid
          which returns
          name                                           hostid itemid value_type history trends hostid
          Download speed for step "$2" of scenario "$1". 10282  29738  0          30d     90d    10282
          Response time for step "$2" of scenario "$1".  10282  29739  0          30d     90d    10282
          Response code for step "$2" of scenario "$1".  10282  29740  3          30d     90d    10282
          so if I create a new Web Scenario and apply it to that template, the SQL is showing results for both the template and the host...
          SELECT
              h.host,
              h.hostid,
              i.name,
              i.hostid,
              i.itemid,
              i.value_type,
              i.history,
              i.trends,
              i.hostid
          FROM
              hosts h,
              items i,
              httpstepitem hi,
              httpstep hs
          WHERE
              h.hostid=i.hostid
          AND    i.itemid=hi.itemid
          host       hostid name                                           hostid itemid value_type history trends hostid
          Web Checks 10282  Download speed for step "$2" of scenario "$1". 10282  29738  0          30d     90d    10282
          Web Checks 10282  Response time for step "$2" of scenario "$1".  10282  29739  0          30d     90d    10282
          Web Checks 10282  Response code for step "$2" of scenario "$1".  10282  29740  3          30d     90d    10282
          Web Checks 10282  Download speed for step "$2" of scenario "$1". 10282  29750  0          30d     90d    10282
          Web Checks 10282  Response time for step "$2" of scenario "$1".  10282  29751  0          30d     90d    10282
          Web Checks 10282  Response code for step "$2" of scenario "$1".  10282  29752  3          30d     90d    10282
          zabbix     10265  Download speed for step "$2" of scenario "$1". 10265  29756  0          30d     90d    10265
          zabbix     10265  Response time for step "$2" of scenario "$1".  10265  29757  0          30d     90d    10265
          zabbix     10265  Response code for step "$2" of scenario "$1".  10265  29758  3          30d     90d    10265
          so it looks like for that Web Scenario that is giving the error, it was never applied to the host, and the corresponding item, httpstepitem and httpstep wasn't created on the host....
          Any ideas why that would happen... it seems intermittent
          • kloczek
            • Jun 2006
            • 1771
            In your last comment still there is no details about I've been asking.
            Just back to this thread when you will finish watching football
            • tolland
              • Apr 2008
              • 20
              OK, so further debugging suggests that under some circumstances, when using the API to create a web scenario on a template, the api fails to insert a httpstepitem record for the httpstep on host which has the template applied to it.
              Unfortunately I have not been able to create a simplified demonstration of the bug, as the simple case of creating a one-shot web scenario works fine, as do my follow up tests from the Web UI
              The problem can be seen from the httpstep and httpstepitem records that were created;
              SELECT
                      h.host hostname,
                     i.*
              FROM
                  hosts h,
                  items i,
                  httpstep hs,
                  httpstepitem hsi
              WHERE  h.hostid = i.hostid
              AND    i.itemid = hsi.itemid
              AND    hsi.httpstepid = hs.httpstepid
              produces this list;
              hostname   itemid type snmp_community snmp_oid hostid name                                           key_                                                            delay history trends status value_type trapper_hosts units snmpv3_securityname snmpv3_securitylevel snmpv3_authpassphrase snmpv3_privpassphrase formula error lastlogsize logtimefmt templateid valuemapid params ipmi_sensor authtype username password publickey privatekey mtime flags interfaceid port description inventory_link lifetime snmpv3_authprotocol snmpv3_privprotocol state snmpv3_contextname evaltype jmx_endpoint master_itemid
              Web Checks 29738  9                            10282  Download speed for step "$2" of scenario "$1". web.test.in[biohackspace.org,biohackspace.org-1,bps]            1m    30d     90d    0      0                        Bps                       0        0                      (null)     (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              Web Checks 29739  9                            10282  Response time for step "$2" of scenario "$1".  web.test.time[biohackspace.org,biohackspace.org-1,resp]         1m    30d     90d    0      0                        s                         0        0                      (null)     (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              Web Checks 29740  9                            10282  Response code for step "$2" of scenario "$1".  web.test.rspcode[biohackspace.org,biohackspace.org-1]           1m    30d     90d    0      3                                                  0        0                      (null)     (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              zabbix     29762  9                            10265  Download speed for step "$2" of scenario "$1". web.test.in[biohackspace.org,biohackspace.org-1,bps]            1m    30d     90d    0      0                        Bps                       0        0                      29738      (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              zabbix     29763  9                            10265  Response time for step "$2" of scenario "$1".  web.test.time[biohackspace.org,biohackspace.org-1,resp]         1m    30d     90d    0      0                        s                         0        0                      29739      (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              zabbix     29764  9                            10265  Response code for step "$2" of scenario "$1".  web.test.rspcode[biohackspace.org,biohackspace.org-1]           1m    30d     90d    0      3                                                  0        0                      29740      (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              Web Checks 29810  9                            10282  Download speed for step "$2" of scenario "$1". web.test.in[londonbiological.com,londonbiological.com-1,bps]    1m    30d     90d    0      0                        Bps                       0        0                      (null)     (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              Web Checks 29811  9                            10282  Response time for step "$2" of scenario "$1".  web.test.time[londonbiological.com,londonbiological.com-1,resp] 1m    30d     90d    0      0                        s                         0        0                      (null)     (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              Web Checks 29812  9                            10282  Response code for step "$2" of scenario "$1".  web.test.rspcode[londonbiological.com,londonbiological.com-1]   1m    30d     90d    0      3                                                  0        0                      (null)     (null)                        0                                               0     0     (null)                       0              30d      0                   0                   0                        0                     (null)
              and you can see from the list of httpstepitem that the records are missing in httpstepitem for the second web scenario for the host that has the template "Web Checks" applied to it;
              httpstepitemid httpstepid itemid type
              238            80         29738  2
              239            80         29739  1
              240            80         29740  0
              253            85         29762  2
              254            85         29763  1
              255            85         29764  0
              286            96         29810  2
              287            96         29811  1
              288            96         29812  0
              There should be 12 records there, not 9....
              My simplified example is working fine, so it must be something in my setup that is triggering the problem
                #!/bin/bash
                  # --trace-ascii -
                authid=$( curl -s --show-error -X POST "http://zabbix/zabbix/api_jsonrpc.php" -H 'Content-Type: application/json' -d"
                \"jsonrpc\": \"2.0\",
                \"method\": \"user.login\",
                \"params\": {
                \"user\": \"${zabbix_user}\",
                \"password\": \"${zabbix_pass}\"
                \"auth\": null,
                \"id\": 0
                }" | jq '.result' | tr -d '"'
                  echo $authid
                  ## {'hostid': u'10282', 'steps': [{'url': 'http://londonbiological.com', 'name':
                # 'londonbiological.com-1', 'no': 1}], 'name': 'londonbiological.com'}
                  curl --trace-ascii - -X POST "http://zabbix/zabbix/api_jsonrpc.php" -H 'Content-Type: application/json' -d @- <<EOF
                "jsonrpc": "2.0",
                "method": "httptest.create",
                "params": {
                "name": "Homepage check",
                "hostid": "10282",
                "steps": [
                "name": "Homepage",
                "url": "http://mycompany.com",
                "no": 1
                "auth": "$authid",
                "id": 1
                EOF
              • tuxick
                tuxick commented
                And on 7.4 i ran into this very same issue, httpstepid not found in httpstepitem. I'm using a Template with a Webcheck using Step URL https://$VHOST}/
                It fails "sometimes", can't find a pattern.
                Host->Latest Data shows the data just fine.
            • tuxick
              • May 2017
              When failing there's 3 items missing in latest data: Download speed for step, Response code for step and Response time for step
