I encountered a problem during upgrade from Zabbix server 2.0.9 to 2.2.1, via openSUSE monitoring repo packages. Previously Zabbix was connecting using a unix-style socket file (instead of a listening network socket). After upgrading, this type of connection seems to be failing - from the server log:
13632:20140204:174820.079 Database is down. Reconnecting in 10 seconds.
13632:20140204:174830.080 [Z3001] connection to database 'zabbix' failed: [0] could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
Note this /tmp/.s.PGSQL.5432 file does exist (& database server is running), and I can verify it works for connection using the command line psql tool.
Previously I'd followed instructions for the zabbix-server.conf file for using unix sockets with Zabbix, by setting DBHost to blank. Relevant snippet below:
DBHost=
DBName=zabbix
DBUser=zabbix
DBSocket=/tmp/.s.PGSQL.5432
While troubleshooting this, I've verified that SELinux is not active, that I can connect using psql via unix-style socket, and that PostgreSQL & Zabbix server ARE actually running.
At this point I am wondering if the syntax in zabbix-server.conf required to force Unix domain socket connections has changed, or is broken, between 2.0.9 and 2.2.1. I've tried fiddling with this also, but so far no luck.
For now I've allowed Postgres to listen on localhost via network socket, and am (successfully) allowing Zabbix to connect that way instead. The database was upgraded properly & new setup is (mostly) working, but I'd like to go back to using Unix sockets if possible.
Before opening a bug, I thought I'd check to see if any others have run into/fixed this type of problem recently. Didn't see any relevant postings here, so here is mine...
Thanks in advance!
DBHost=
DBName=zabbix
DBUser=zabbix
Thanks in advance!
