Hi.
I'm using zabbix server 3.4.6
Zabbix agent is on version 3.0.7 (latest from jessie backports).
I've noticed some services being down and zabbix didn't alert me, so I asked myself why is that. Doing some troubleshooting I've noticed that zabbix_get on host with checking item is returning different value compared to the same command executed directly on zabbix agent.
Example:
- zabbix agent have user param defined item:
UserParameter=check.nfs.process,ps auxw | grep nfs | wc -l
If I execute that command directly on zabbix agent it returns value - e.g. 2, but if I run on zabbix server zabbix_get
# zabbix_get -s AGENT_IP -p 10050 -k check.nfs.process
I will get value 3 (one more). Why does this happen? I've other checks with grep-ing string and it works just fine.
How to troubleshoot this difference?
Example:
