Zabbix Trapper Memeory Leak
  • desmondho
    • Feb 2014
    Dear all,
    Here is my Zabbix environment details:
    Version: Zabbix-server 2.2.1
    Number of Hosts: 338
    Number of Items: 5162
    Distributed with totally 4 nodes
    My Zabbix server is having a serious memory leak problem as attached.Click image for larger version
    And it seems the Zabbix Trapper process holding the memory and will not release until restart the zabbix-server.
    I would like to know if anyone have a solution or countering this problem
    Sorry for my bad English and thanks a lot~!
    Best regards,
    Desmond Ho
  • desmondho
    • Feb 2014
    After days of investigating, i found the RAM was consumed by the events update from distributing nodes.
    I fixed it by enable NodeNoEvents=1 on all child nodes.
    It would be appreciate if Zabbix Team found the root cause and fix it.
