Problems after upgrade 3.2 > 3.4.11
  • christovam
    • Dec 2015
    • 10
    I was running zabbix 3.2 and upgraded to version 3.4.11. I always compile the version using ./configure + parameters and update the frontend files since version 1.8.
    After this upgrade several items collected by the Zabbix Agent or SNMP are not being updated. Many values are empty.
    If I run via CLI, I can collect the value correctly. "/ usr / local / zabbix / bin / zabbix_get -s 200.xxx.xxx.xx -k system.boottime
    1528713106 "
    In the dashboard, in the latest date, the items are without values. I already recompiled the zabbix server, I changed the server zabbix Frontend. But it still did not work out.
    Is someone going through this?
    Attached images.
  • christovam
    • Dec 2015
    • 10
    My environment is: CentOS release 6.10 (Final) with PHP 7.0
    • ingus.vilnis
      • Mar 2014
      • 908
      zabbix_server.log file plus Zabbix internal graphs might give you more clues here.
