Wrong SQL queries in default zabbix script leads to errors
  • Alwaysin
    • Jan 2012
    • 27
    [OK sry, found a bug report https://support.zabbix.com/browse/ZB...ream-issue-tab and saw it is corrected in 2.2.2]
    I'm not sure about it but it look like Zabbix executes wrong SQL command related to IPMI :
    31726:20140213:133748.944 [Z3005] query failed: [1054] Unknown column 'impi_available' in 'field list' [update hosts set impi_available=1,impi_error='' where hostid=10236]
    impi_available should be ipmi_available (I checked in the DB, that's it)
    where can I correct this so that my IPMI icon becomes green ?
    (Also, should I create a bug for this ?)
    Thanks,
    /Adrien.
