Running Zabbix version 2.0.10 on both server and Agent. Both systems are CentOS 6.5 x86_64 with matching zabbix software using x86_64 as well.
If I run the autodiscovery from the zabbix server I get:
I see the / filesystem listed as both "rootfs" and "ext4".
I have created a template with an Autodiscovery rule:
Name: Filesystem Discovery
Type: Zabbix Agent (active)
Key: vfs.fs.discovery
Filter Macro: NONE
I have created an item prototype:
Name: Used disk space: $1
Key: vfs.fs.size[{#FSNAME},used]
Type of information: Numeric (float)
Units: B
Both are enable and working with one exception. I can see all filesystems on the box in the UI with one exception the root filesystem ,"/", does not appear. I can see items for /proc, /sys, /boot, etc.
Is this by design? Is it because I should be creating a normal item to track "/" since this is a required filesystem on linux?
]# zabbix_get --host=mach --key=vfs.fs.discovery
"data":[
"{#FSNAME}":"\/",
"{#FSTYPE}":"rootfs"},
"{#FSNAME}":"\/proc",
"{#FSTYPE}":"proc"},
"{#FSNAME}":"\/sys",
"{#FSTYPE}":"sysfs"},
"{#FSNAME}":"\/dev",
"{#FSTYPE}":"devtmpfs"},
"{#FSNAME}":"\/dev\/pts",
"{#FSTYPE}":"devpts"},
"{#FSNAME}":"\/dev\/shm",
"{#FSTYPE}":"tmpfs"},
"{#FSNAME}":"\/",
"{#FSTYPE}":"ext4"},
"{#FSNAME}":"\/proc\/bus\/usb",
"{#FSTYPE}":"usbfs"},
"{#FSNAME}":"\/boot",
"{#FSNAME}":"\/proc\/sys\/fs\/binfmt_misc",
"{#FSTYPE}":"binfmt_misc"},
"{#FSNAME}":"\/misc",
"{#FSTYPE}":"autofs"},
"{#FSNAME}":"\/net",
"{#FSTYPE}":"autofs"}]}
Filter Macro: NONE
Units: B
