Trouble getting snmp listener working in Zabbix 3.4 on Ubuntu
  • surfrock66
    • Jul 2018
    • 30
    I'm setting up a brand new Zabbix instance, version 3.4.11, on Ubuntu Server 18.04 and Zabbix itself appears to be working, but I'm having issues getting the SNMP listener to work. On one hand I think it's running and I'm receiving test traps, but i'm not getting any data including discovery off the first host I am looking at. I've followed a bunch of configuration guides, but I'm stumped. I've updated all templates/items with our community name.
    The core issue is, I have a cisco catalyst at 10.1.1.1 (this is our first SNMP device, added as a test) and I have set up "Template Module Cisco Inventory SNMPv2" on it, but in the zabbix logs I get the following:
     temporarily disabling SNMP agent checks on host "10.1.1.1": host unavailable
    I can ping the device. The firewall is off on the zabbix server:
    # ufw status
    Status: inactive
    In the GUI, I have a RED SNMP box next to the host with hover-text "Timeout while connecting to 10.1.1.1:161."
    When I run this:
    snmptrap -v 1 -c public 127.0.0.1 '.1.3.6.1.6.3.1.1.5.4' '0.0.0.0' 6 33 '55' .1.3.6.1.6.3.1.1.5.4 s "eth0"
    My trap file shows this:
    08:36:53 2018/07/18 ZBXTRAP 127.0.0.1
    PDU INFO:
      version                        0
      errorstatus                    0
      receivedfrom                   UDP: [127.0.0.1]:54995->[127.0.0.1]:162
      requestid                      0
      messageid                      0
      transactionid                  1
      errorindex                     0
      community                      public
      notificationtype               TRAP
    VARBINDS:
      iso.3.6.1.2.1.1.3.0            type=67 value=Timeticks: (55) 0:00:00.55
      iso.3.6.1.6.3.1.1.4.1.0        type=6  value=OID: iso.3.6.1.6.3.1.1.5.4.0.33
      iso.3.6.1.6.3.1.1.5.4          type=4  value=STRING: "eth0"
      iso.3.6.1.6.3.18.1.4.0         type=4  value=STRING: "public"
      iso.3.6.1.6.3.1.1.4.3.0        type=6  value=OID: iso.3.6.1.6.3.1.1.5.4
    That makes me think things are working, but I can't actually monitor my device.
    Below is a dump of relevant configs and scripts.
    /etc/zabbix/zabbix_server.conf
    LogFile=/var/log/zabbix/zabbix_server.log
    LogFileSize=0
    PidFile=/var/run/zabbix/zabbix_server.pid
    SocketDir=/var/run/zabbix
    DBName=zabbix
    DBUser=zabbix
    DBPassword=##REDACTED##
    SNMPTrapperFile=/var/log/zabbix_traps.log
    StartSNMPTrapper=1
    Timeout=4
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    FpingLocation=/usr/bin/fping
    Fping6Location=/usr/bin/fping6
    LogSlowQueries=3000
    /etc/snmp/snmptrapd.conf
    disableAuthorization yes
    traphandle default snmptt
    perl do "/etc/zabbix/zabbix_trap_receiver/zabbix_trap_receiver.pl"
    $SNMPTrapperFile = '/var/log/zabbix_traps.log';
    $DateTimeFormat = '%H:%M:%S %Y/%m/%d';
    use Fcntl qw(O_WRONLY O_APPEND O_CREAT);
    use POSIX qw(strftime);
    sub zabbix_receiver
            my (%pdu_info) = %{$_[0]};
            my (@varbinds) = @{$_[1]};
            # open the output file
            unless (sysopen(OUTPUT_FILE, $SNMPTrapperFile, O_WRONLY|O_APPEND|O_CREAT, 0666))
                    print STDERR "Cannot open [$SNMPTrapperFile]: $!\n";
                    return NETSNMPTRAPD_HANDLER_FAIL;
            # get the host name
            my $hostname = $pdu_info{'receivedfrom'} || 'unknown';
            if ($hostname ne 'unknown') {
                    $hostname =~ /\[(.*?)\].*/;                    # format: "UDP: [127.0.0.1]:41070->[127.0.0.1]"
                    $hostname = $1 || 'unknown';
            # print trap header
            #       timestamp must be placed at the beggining of the first line (can be omitted)
            #       the first line must include the header "ZBXTRAP [IP/DNS address] "
            #              * IP/DNS address is the used to find the corresponding SNMP trap items
            #              * this header will be cut during processing (will not appear in the item value)
            printf OUTPUT_FILE "%s ZBXTRAP %s\n", strftime($DateTimeFormat, localtime), $hostname;
            # print the PDU info
            print OUTPUT_FILE "PDU INFO:\n";
            foreach my $key(keys(%pdu_info))
                    printf OUTPUT_FILE "  %-30s %s\n", $key, $pdu_info{$key};
            # print the variable bindings:
            print OUTPUT_FILE "VARBINDS:\n";
            foreach my $x (@varbinds)
                    printf OUTPUT_FILE "  %-30s type=%-2d value=%s\n", $x->[0], $x->[2], $x->[1];
            close (OUTPUT_FILE);
            return NETSNMPTRAPD_HANDLER_OK;
    NetSNMP::TrapReceiver::register("all", \&zabbix_receiver) or
            die "failed to register Zabbix SNMP trap receiver\n";
    print STDOUT "Loaded Zabbix SNMP trap receiver\n";
    /etc/snmp/snmptt.conf
    EVENT coldStart .1.3.6.1.6.3.1.1.5.1 "Status Events" Normal
    FORMAT Device reinitialized (coldStart)
    EVENT warmStart .1.3.6.1.6.3.1.1.5.2 "Status Events" Normal
    FORMAT Device reinitialized (warmStart)
    EVENT linkDown .1.3.6.1.6.3.1.1.5.3 "Status Events" Normal
    FORMAT Link down on interface $1.  Admin state: $2.  Operational state: $3
    EVENT linkUp .1.3.6.1.6.3.1.1.5.4 "Status Events" Normal
    FORMAT Link up on interface $1.  Admin state: $2.  Operational state: $3
    EVENT authenticationFailure .1.3.6.1.6.3.1.1.5.5 "Status Events" Normal
    FORMAT SNMP athentication failure
    EVENT general .* "General event" Normal
    FORMAT ZBXTRAP $aA $ar
    /etc/snmp/snmptt.ini
    [General]
    snmptt_system_name =
    mode = standalone
    multiple_event = 1
    dns_enable = 0
    strip_domain = 0
    strip_domain_list = <<END
    domain.com
    END
    resolve_value_ip_addresses = 0
    net_snmp_perl_enable = 0
    net_snmp_perl_cache_enable = 1
    net_snmp_perl_best_guess = 0
    translate_log_trap_oid = 0
    translate_value_oids = 1
    translate_enterprise_oid_format = 1
    translate_trap_oid_format = 1
    translate_varname_oid_format = 1
    translate_integers = 1
    wildcard_expansion_separator = " "
    allow_unsafe_regex = 0
    remove_backslash_from_quotes = 0
    dynamic_nodes = 0
    description_mode = 0
    description_clean = 1
    threads_enable = 0
    threads_max = 10
    date_time_format = %H:%M:%S %Y/%m/%d
    [DaemonMode]
    daemon_fork = 1
    daemon_uid = snmptt
    pid_file = /var/run/snmptt.pid
    spool_directory = /var/spool/snmptt/
    sleep = 5
    use_trap_time = 1
    keep_unlogged_traps = 1
    duplicate_trap_window = 0
    [Logging]
    stdout_enable = 0
    log_enable = 1
    log_file = /var/log/zabbix_traps.log
    log_system_enable = 0
    log_system_file = /var/log/snmptt/snmpttsystem.log
    unknown_trap_log_enable = 0
    unknown_trap_log_file = /var/log/snmptt/snmpttunknown.log
    statistics_interval = 0
    syslog_enable = 1
    syslog_facility = local0
    syslog_level_debug = <<END
    END
    syslog_level_info = <<END
    END
    syslog_level_notice = <<END
    END
    syslog_level_warning = <<END
    END
    syslog_level_err = <<END
    END
    syslog_level_crit = <<END
    END
    syslog_level_alert = <<END
    END
    syslog_level = warning
    syslog_system_enable = 1
    syslog_system_facility = local0
    syslog_system_level = warning
    [SQL]
    db_translate_enterprise = 0
    db_unknown_trap_format = '$-*'
    sql_custom_columns = <<END
    END
    sql_custom_columns_unknown = <<END
    END
    mysql_dbi_enable = 0
    mysql_dbi_host = localhost
    mysql_dbi_port = 3306
    mysql_dbi_database = snmptt
    mysql_dbi_table = snmptt
    mysql_dbi_table_unknown = snmptt_unknown
    mysql_dbi_table_statistics =
    mysql_dbi_username = snmpttuser
    mysql_dbi_password = password
    mysql_ping_on_insert = 1
    mysql_ping_interval = 300
    postgresql_dbi_enable = 0
    postgresql_dbi_module = 0
    postgresql_dbi_hostport_enable = 0
    postgresql_dbi_host = localhost
    postgresql_dbi_port = 5432
    postgresql_dbi_database = snmptt
    postgresql_dbi_table_unknown = snmptt_unknown
    postgresql_dbi_table_statistics =
    postgresql_dbi_table = snmptt
    postgresql_dbi_username = snmpttuser
    postgresql_dbi_password = password
    postgresql_ping_on_insert = 1
    postgresql_ping_interval = 300
    dbd_odbc_enable = 0
    dbd_odbc_dsn = snmptt
    dbd_odbc_table = snmptt
    dbd_odbc_table_unknown = snmptt_unknown
    dbd_odbc_table_statistics =
    dbd_odbc_username = snmptt
    dbd_odbc_password = password
    dbd_odbc_ping_on_insert = 1
    dbd_odbc_ping_interval = 300
    [Exec]
    exec_enable = 1
    pre_exec_enable = 1
    unknown_trap_exec =
    unknown_trap_exec_format =
    exec_escape = 1
    [Debugging]
    DEBUGGING = 0
    DEBUGGING_FILE =
    DEBUGGING_FILE_HANDLER =
    [TrapFiles]
    snmptt_conf_files = <<END
    END
    Here are the running processes, with their associated user accounts:
    ps -ef | grep snmp
    root        636      1  0 Jul17 ?        00:00:00 /usr/sbin/snmptrapd -Lsd -f
    Debian-+    662      1  0 Jul17 ?        00:00:15 /usr/sbin/snmpd -Lsd -Lf /dev/null -u Debian-snmp -g Debian-snmp -I -smux mteTrigger mteTriggerConf -f
    root        932      1  0 Jul17 ?        00:00:00 /usr/bin/perl /usr/sbin/snmptt --daemon
    snmptt      933    932  0 Jul17 ?        00:00:00 /usr/bin/perl /usr/sbin/snmptt --daemon
    zabbix     1061    989  0 Jul17 ?        00:00:02 /usr/sbin/zabbix_server: snmp trapper [processed data in 0.000010 sec, idle 1 sec]
    root       5881   5734  0 10:02 pts/0    00:00:00 grep --color=auto snmp
    Any thoughts? There are a ton of things in the logs like this:
    Cannot find module
    Cannot adopt OID in UCD-SNMP-MIB:
    Cannot adopt OID in NET-SNMP-AGENT-MIB:
  • khemrajk2003
    • Jan 2017
    Hi Surrock66, I am by no means an expert in Zabbix, but I just happen to come across this post. You may have already resolved this issue since the post is about a month old. I am currently setting up SNMP traps on our Zabbix Proxy. Where you able to resolve this? Can you send a test trap from your CISCO device to your Zabbix server and see the traps in the log; can you query your CISCO device from your Zabbix server? The RED SNMP indicates a communication issue between your Zabbix server and the CISCO device, are there any firewalls (not the local one on your Zabbix server) that may be dropping the request? Did you define the Zabbix server as a trap destination on the CISCO device and or allow snmp queries from your Zabbix server. One thing I notice, with your snmptrapd.conf file (this would not fix your issue, but I was just wondering), I was under the impression that you either use snmptt to handle the traps or you use the Zabbix Perl script to handle the traps. I literally setup a new Zabbix Proxy to replace (soon) our current one that is used to handle snmp devices and I just used the Zabbix trap Perl script (referenced it in the snmptrapd.conf file) and the traps are working. It looks like your issue is just the communication between your Zabbix server and the CISCO device.
    • khemrajk2003
      • Jan 2017
      Sorry about the type with your name, I meant surfrock66.
      • surfrock66
        • Jul 2018
        • 30
        Sort of. It came down to the fact that the community string isn't being respected. Our organization uses a non-standard community string for most devices, but select devices use the default "public." If we set the global macro with the off-standard community string, then override it on the host itself, it doesn't get respected. I debugged this using snmpwalk;
        snmpwalk -v 2c -c public -O bn -C i 10.1.2.2 .1.3.6.1.2.1.1.5.0
        snmpwalk -v 2c -c <<other community>> -O bn -C i 10.1.2.2 .1.3.6.1.2.1.1.5.0
        I just deleted and recreated the hosts a bunch of times then it worked I've heard of people using MEGA old versions (1.8) looking in the DB and seeing that the effective community string is correct, but I didn't do that.
