Not sure where to post this but I cannot access repo.zabbix.com from my OVH VPS so I can't install Zabbix. I compared traceroutes between a place that works and the VPS so I am confident it isn't a routing issue. I can access it from elsewhere so I think some kind of firewall running on the repo side is blocking my IP (158.69.203.X).
Is there any current repo mirrors?
Thanks,
Vincent
# rpm -ivh https://repo.zabbix.com/zabbix/3.4/r...el7.noarch.rpm
Retrieving https://repo.zabbix.com/zabbix/3.4/r...el7.noarch.rpm
curl: (7) Failed connect to repo.zabbix.com:443; Connection timed out
error: skipping https://repo.zabbix.com/zabbix/3.4/r...el7.noarch.rpm - transfer failed
Thanks,
Vincent
