Hi all,
I'm adding a new trigger that checks interface errors using SNMP. However now the trigger starts when the interface error counter is already above 2. What i really want:
- Check the average value over the last 3 datapoints
- Only if the next interface error value has a higher difference than 2 or more over the average it should be true
Right now i have a interface which has 10 errors (over 1 year). But the trigger is true because 10 > 2. What i really want is the average over last 15 minutes (3 datapoints, each one gathered over 5 minutes) is 10. Compare that with the current value. If it's higher than 2, than should be True. So 12 or more errors should be True in this case.
Sorry if it's a bit vague, hopefully you guys can help me
