vfs.fs.size [# FSNAME, pfree] is not supported
  • mfdzerohour
    • Jun 2018
    Good morning, if I use the zabbix discovery feature, it shows me the information related to vfs.fs.size [# FSNAME, free], showing the information correctly, now if I use vfs.fs.size [#FSNAME, pfree] it shows as unsupported, if I inform you what would be the partition vfs.fs.size [/, pfree] it shows me the result, ie it is something related to discovery, someone went through it? Or should I report it as a bug? I am asking this question because as I am still starting with zabbix, there may be errors on my part, and not the same, if it is zabbix error, I would like to inform the same, if you can answer me thank you.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Do you use set "Type of information" to "Numeric (float)" in the item prototype of pfree?
    Please attach a screenshot of pfree item prototype configuration ("Configuration -> Hosts -> Discovery -> Item prototypes -> item with pfree").
