Active check on logs report fifferent values depending on Operator
  • syn4ps
    • Jul 2018
    Hello everyone,
    I was new to Zabbix one month ago so I am still learning. And still have problems.
    I have created 2 items (active checks) which look for invalid connection attempts via ssh:
    item one: log.count[/var/log/auth.log,: Invalid user ]
    item two: log.count[/var/log/auth.log,: Invalid user .* 192.168.23.26]
    The second one is here to avoid raising an alarm if the IP 192.168.23.26 made the failed connection attempt.
    The correspondent trigger is:
    {Template Authentication failure - Debian-like:log.count[/var/log/auth.log,: Invalid user .* 192.168.23.26].last()}=0 and {Template Authentication failure - Debian-like:log.count[/var/log/auth.log,: Invalid user ].last()}>3
    The graphs work well in the "monitoring/latest data", both items show what they are supposed to show, but the mail I receive show wrong values (I have made the login attempts from host2 192.168.23.26):
    Item values:
    1. Log check - Discard host2 Invalid connexion attempts Debian-like (host1:log.count[/var/log/auth.log,: Invalid user .* 192.168.23.26]): 0
    2. Log check - Invalid connexion attempts Debian-like (host1:log.count[/var/log/auth.log,: Invalid user ]): 7
    it should have been 7 and 7!
    Now the weird thing... Same items, just one operator in trigger has changed:
    {Template Authentication failure - Debian-like:log.count[/var/log/auth.log,: Invalid user .* 192.168.23.26].last()}>0 and {Template Authentication failure - Debian-like:log.count[/var/log/auth.log,: Invalid user ].last()}>3
    The mail I receive:
    Item values:
    1. Log check - Discard nessus Invalid connexion attempts Debian-like (alf:log.count[/var/log/auth.log,: Invalid user .* 192.168.23.26]): 8
    2. Log check - Invalid connexion attempts Debian-like (alf:log.count[/var/log/auth.log,: Invalid user ]): 8
    Good values! 8 and 8
    Does anybody know what I do wrong?
    Cheers!
