Issue with proc.num
  • mpt
    • Aug 2018
    Issue with proc.num
    I'm running into issue when trying to get the process count using proc.num. Currently running the Zabbix Server 3.4.4 with the same agent version on RHEL 7.3. I followed the steps provided here
    [root@zabbix1 ~]#  ps -ef | grep zabbix_agentd
    zabbix   24201     1  0 Aug04 ?        00:00:00 /usr/sbin/zabbix_agentd -c /etc/zabbix/zabbix_agentd.conf
    zabbix   24202 24201  0 Aug04 ?        00:01:12 /usr/sbin/zabbix_agentd: collector [idle 1 sec]
    zabbix   24203 24201  0 Aug04 ?        00:05:36 /usr/sbin/zabbix_agentd: listener #1 [waiting for connection]
    zabbix   24204 24201  0 Aug04 ?        00:00:00 /usr/sbin/zabbix_agentd: listener #2 [waiting for connection]
    zabbix   24205 24201  0 Aug04 ?        00:05:32 /usr/sbin/zabbix_agentd: listener #3 [waiting for connection]
    zabbix   24206 24201  0 Aug04 ?        00:00:17 /usr/sbin/zabbix_agentd: active checks #1 [idle 1 sec]
    but it only returned 1 instead of 6
    [root@zabbix1 ~]# zabbix_get -s 127.0.0.1 -k 'proc.num[zabbix_agentd,zabbix]'
    1
    So I enabled more debugging on the agent log and saw the following and it seemed to me zabbix_get was only able to retrieve and see its own process and not the other 6 processes running abbix_agentd.
    Requested [proc.num[zabbix_agentd,zabbix]]
    Sending back [1]
    I'm not certain where or why the process is missing or not available from zabbix_get command. Can someone please help?
  • mpt
    • Aug 2018
    Just want to answer my own question. The hardened RHEL in question has hidepid=2 set on /proc which prevents regular zabbix user from seeing other users' processes. The fix was to create another monitoring group, add the zabbix user to that group, and remount /proc with gid of monitoring group.
    https://www.cyberciti.biz/faq/linux-...m-other-users/
