Configuring SMTP
  • dividedby0
    • Jul 2006
    Configuring SMTP
    Hello everybody
    I hope you'll answer to my problem.
    In the Initial Configuration, where do we enter the SNMP configuration?
    I dont have any link
    Which SNMP Server shall I use?
    Thanks for your help
  • xaitax
    • Apr 2006
    • 39
    In the topic is SMTP and content is about SNMP. Quite confusing.
    - xai
    • dividedby0
      • Jul 2006
      configuring snmp
      In the Initial Configuration of Zabbix presented in the site
      "Once your ZABBIX installation is complete, you will need to configure ZABBIX. Point your web browser to the location you installed the PHP scripts to. (For example, if you copied the PHP files to /home/zabbix/public_html or /home/zabbix/html, point your browser to http://localhost/~zabbix.
      Once there, click on the CONFIG link. You will be prompted for a username and password. ZABBIX comes pre-configured with an administrative account: Enter the username Admin and leave the password field empty.
      Add the configuration of your SMTP server of choice. "
      But there is no SMTP link
      Thank you again
      • dividedby0
        • Jul 2006
        Smtp
        sorry ZAITAX
        I made a mistake!
        the subject is SMTP you're right.
        I suppose SMTP will be used to send a trap by mail!
        Thank you for your help, Im newbie in Zabbix
        Regards
