On fresh Ubuntu 16.04 just installed I installed new Zabbix 3.4 and during frontend setup I'm stuck with "The frontend does not match Zabbix database.".
Commands used to install Zabbix
wget https://repo.zabbix.com/zabbix/3.4/u...xenial_all.deb
dpkg -i zabbix-release_3.4-1+xenial_all.deb
apt update
apt install zabbix-server-pgsql
apt install zabbix-frontend-php
apt install php-pgsql
sudo apt-get install snmp
apt-get install snmp-mibs-downloader
# postgresql
sudo -i -u postgres
# create postgres role "zabbix" (superuser, before tried not superuser)
createuser --interactive
psql
CREATE DATABASE zabbix;
alter role zabbix with password 'test.test.test.';
zcat /usr/share/doc/zabbix-server-pgsql/create.sql.gz | sudo -u zabbix psql zabbix
# vi /etc/zabbix/zabbix_server.conf
DBHost=localhost
DBName=zabbix
DBUser=zabbix
DBPassword=test.test.test.
# start
service zabbix-server start
update-rc.d zabbix-server enable
# edit /etc/apache2/conf-enabled/zabbix.conf
php_value date.timezone Europe/Warsaw
service apache2 restart
from zabbix_server.log:
11712:20180829:051449.428 Zabbix Server stopped. Zabbix 3.4.13 (revision 84139).
11821:20180829:051449.464 Starting Zabbix Server. Zabbix 3.4.13 (revision 84139).
11821:20180829:051449.465 ****** Enabled features ******
11821:20180829:051449.465 SNMP monitoring: YES
11821:20180829:051449.465 IPMI monitoring: YES
11821:20180829:051449.465 Web monitoring: YES
11821:20180829:051449.465 VMware monitoring: YES
11821:20180829:051449.465 SMTP authentication: YES
11821:20180829:051449.465 Jabber notifications: YES
11821:20180829:051449.465 Ez Texting notifications: YES
11821:20180829:051449.465 ODBC: YES
11821:20180829:051449.465 SSH2 support: YES
11821:20180829:051449.465 IPv6 support: YES
11821:20180829:051449.465 TLS support: YES
11821:20180829:051449.466 ******************************
11821:20180829:051449.466 using configuration file: /etc/zabbix/zabbix_server.conf
11821:20180829:051449.497 current database version (mandatory/optional): 03040000/03040007
11821:20180829:051449.497 required mandatory version: 03040000
11821:20180829:051449.538 server #0 started [main process]
... (1-32 all started)
11862:20180829:051450.160 server #33 started [preprocessing worker #3]
In browser at the bottom of config screen with 'The frontend does not match Zabbix database.' error I have:
Zabbix 3.4.13. © 2001–2018, Zabbix SIA
Help!
Radek
apt update
# postgresql
sudo -i -u postgres
psql
DBHost=localhost
DBName=zabbix
DBUser=zabbix
# start
Help!
Radek
