Problem with templates
  • Bogdan
    • Aug 2018
    I am quite new to zabbix monitoring system. I have a few problems:
    1) I can't choose and add aTemplate from the list when I am adding a new monitored host. It only shows "Host updated".
    2)Second thing is that the console does not show that is sees other agents. But when i run zabbix_get -k system.uname -s 192.168.11.111 through the terminal it self seems to recognize the agent (Linux Agent 3.10.0-123.el7.x86_64 #1 SMP Mon Jun 30 12:09:22 UTC 2014 x86_64)
    Thanks in advance.
  • Kirin2
    • Jul 2018
    • 28
    Make sure that you're following these steps:
    1) Choose template;
    2) Click button "Add" under textbox with template name (IMPORTANT)
    3) Click Update
    • Bogdan
      • Aug 2018
      Originally posted by Kirin2
      Make sure that you following this steps:
      1) Choose template;
      3) Click Update
      Sorry, I have done this step numerous times. Maybe something may be wrong with server configuration. I have installed zabbix by following this tutorial.
      Any more ideas?
      • Kirin2
        • Jul 2018
        • 28
        Does it show you "Host updated" in green rectangle when you click Update?
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          On your screenshot you have empty "Templates" column. It means after selecting the template you forgot to click "Add" and "Update".
          • Bogdan
            • Aug 2018
            Correct! You are totally right. When i select a template and press add or update the console Host updated.
