I'm trying to install Zabbix 3.4 but i get this error message:
PHP Doc's say that there is no php-mysql for php7
Zabbix doc in English say to use php 5.4 or later (https://www.zabbix.com/documentation...n/requirements) in portuguese there is a observation about the PHP 7.0 on software requirements -
(PHP 7 is not supported)- (https://www.zabbix.com/documentation...n/requirements).
Zabbix 3.4 support php 7 yes or no - this is a problem or just a misunderstanding in the zabbix documentation?
If yes, how can I use with mysql.
OS: Oracle Linux 7
PHP Repo: https://yum.oracle.com/repo/OracleLinux/OL7/
Zabbix Repo: http://repo.zabbix.com/zabbix/3.4/rhel/7/
# yum install zabbix-web.noarch zabbix-web-mysql.noarch
Loaded plugins: langpacks, ulninfo
Resolving Dependencies
--> Running transaction check
---> Package zabbix-web.noarch 0:3.4.14-1.el7 will be installed
---> Package zabbix-web-mysql.noarch 0:3.4.14-1.el7 will be installed
--> Processing Dependency: php-mysql for package: zabbix-web-mysql-3.4.14-1.el7.noarch
Package php-mysql-5.4.16-45.el7.x86_64 is obsoleted by php-mysqlnd-7.2.10-1.0.1.el7.x86_64 which is already installed
--> Finished Dependency Resolution
Error: Package: zabbix-web-mysql-3.4.14-1.el7.noarch (zabbix)
Requires: php-mysql
Available: php-mysql-5.4.16-45.el7.x86_64 (ol7_latest)
php-mysql = 5.4.16-45.el7
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
This extension was deprecated in PHP 5.5.0, and it was removed in PHP 7.0.0. Instead, the MySQLi or PDO_MySQL extension should be used. See also MySQL: choosing an API guide and related FAQ for more information. Alternatives to this function include:
A versão 7 do PHP ainda não é suportada.
OS: Oracle Linux 7
