jmx monitoring by zabbix java gateway not working
  • kalleinz
    • Mar 2014
    Hello
    I can't monitor tomcat jmx items with zabbix java gateway.
    Versions: RHEL 2.6.32-358.14.1.el6.x86_64, zabbix 2.0.8, zabbix-java-gateway-2.0.8-1.el6.art.x86_64.rpm, apache-tomcat-7.0.41.
    I tried the installation of the zabbix-java-gateway on one machine with the zabbix server and on a different machine.
    I installed both the server and the gateway via rpm (yum install ...).
    I have a nonsense error message in the zabbix web frontend for a server:
    "cannot connect to [[10.197.233.12]:9840]: [113] No route to host".
    The ip .12 is in a different line, the port 9840 is not configured for the server. There is no firewall between the servers and iptables is switched off.
    Regards,
    kalleinz
  • kalleinz
    • Mar 2014
    new zabbix server installation
    Hello
    I installed the zabbix server from packages from scratch and the jmx monitoring worked straightforward.
    The thread can be closed.
    Thanks and regards,
    kalleinz
