Genarate SNMP trap item from alarm list from telnet :: solved :)
  • prasad_SL
    • May 2018
    • 35
    This is the way I did...
    1. Modified external telnet script to dump the output to a file (log)
    2. Read the file and extract lines specific regex and put in to another file; (marked as Newlog)
    3. Append the file content by formatting according to SNMP lines
    I did it by 6 scripts; including telnet script.
    As follows.
    1. telnet script
    #!/usr/bin/expect
    spawn telnet x.x.x.x
    send "username"
    send "\r"
    send "password"
    send "\r"
    expect "Windows NT Domain:"
    send "\r"
    expect ">"
    send "mml -a"
    send "\r"
    expect "<"
    send "alarmlist command;"
    send "\r"
    send "exit \r"
    send "exit \r"
    2. Main command script : : this is the external script places at /usr/lib/zabbix/externalscripts
    Alarm dump location is /home/appliance/prasadAXEscripts
    #!/bin/bash
    /usr/lib/zabbix/externalscripts/isc4A1.sh | tee /home/appliance/prasadAXEscripts/log.txt
    sleep 0.25
    /home/appliance/prasadAXEscripts/Tony_v1.bash
    sleep 0.1
    3. Here Tony_v1.bash will trigger 3 new scripts ...
    #!/bin/bash
    #Extracting A1 and A2 alarms from capture file
    /home/appliance/prasadAXEscripts/Mark42AXEAlarmExtractor_v1.sh
    sleep 0.1
    #Compare New list with Old list and genarate Triggers
    /home/appliance/prasadAXEscripts/Mark43AXEFileAnalyser_v1.bash
    sleep 0.1
    #Tunneling genarated Triggers to Zabbix SNMP train
    /home/appliance/prasadAXEscripts/Mark47SnmpTunnel_v1.sh
    sleep 0.1
    Following are those 3 files...
    If you have any better way or issues ...please comment.
    4. Mark42AXEAlarmExtractor_v1.sh
    #!/bin/bash
    REGEX="^(A1|A2).*"
    file="/home/appliance/prasadAXEscripts/PrasadAXE10log.txt"
    while IFS= read -r line
    do
    if [[ "$line" =~ $REGEX ]]
    then
    echo "$line" >> /home/appliance/prasadAXEscripts/PrasadAXE10logNEW.txt
    fi
    done < "$file"
    5. Mark43AXEFileAnalyser_v1.bash
    #!/bin/bash
    #reading new file to arrayNEW
    file="/home/appliance/prasadAXEscripts/PrasadAXE10logNEW.txt"
    while IFS= read -r line || [[ -n "$line" ]];
    do
    line=$(echo "$line" | tr -d '\r')
    arrayNEW+=("$line")
    done < "$file"
    #reading old file to arrayOLD
    file="/home/appliance/prasadAXEscripts/PrasadAXE10logOLD.txt"
    do
    arrayOLD+=("$line")
    done < "$file"
    for ((k=0; k < ${#arrayNEW[*]}; k++))
    do
    for ((z=0; z < ${#arrayOLD[*]}; z++))
    do
    if [ "${arrayNEW[k]}" = "${arrayOLD[z]}" ];
    #then echo "${arrayNEW[k]}"
    #then arrayBoth+=("${arrayNEW[k]}")
    then
    break
    fi
    var=$((z+1))
    if [ $var = ${#arrayOLD[*]} ];
    #then echo "Not in old file..${arrayNEW[k]}"
    then arrayNewOnly+=("${arrayNEW[k]}")
    fi
    done
    if [ ${#arrayOLD[*]} = 0 ];
    fi
    done
    for ((a=0; a < ${#arrayOLD[*]}; a++))
    do
    for ((b=0; b < ${#arrayNEW[*]}; b++))
    do
    if [ "${arrayOLD[a]}" = "${arrayNEW[b]}" ];
    then
    break
    fi
    var=$((b+1))
    if [ $var = ${#arrayNEW[*]} ];
    #then echo "Not in old file..${arrayOLD[k]}"
    then arrayOldOnly+=("${arrayOLD[a]}")
    fi
    done
    if [ ${#arrayNEW[*]} = 0 ];
    fi
    done
    # File appending
    >/home/appliance/prasadAXEscripts/Mark11snmptraps.txt
    for ((p=0; p < ${#arrayNewOnly[*]}; p++))
    do
    echo "${arrayNewOnly[p]} :: RatFire" >> /home/appliance/prasadAXEscripts/Mark11snmptraps.txt
    done
    for ((q=0; q < ${#arrayOldOnly[*]}; q++))
    do
    echo "${arrayOldOnly[q]} :: RatClear" >> /home/appliance/prasadAXEscripts/Mark11snmptraps.txt
    done
    # File swapping
    cp /home/appliance/prasadAXEscripts/PrasadAXE10logNEW.txt /home/appliance/prasadAXEscripts/PrasadAXE10logOLD.txt
    6. Mark47SnmpTunnel_v1.sh
    #!/bin/bash
    ratT="$(date +'%Y%m%d.%H%M%S')"
    ratip="x.x.x.x"
    file="/home/appliance/prasadAXEscripts/Mark11snmptraps.txt"
    do
    echo "$ratT ZBXTRAP $ratip PrasadAXEalarm $line" >> /var/log/snmptrap/snmptrap.log
    done < "$file"
