No permissions for system access.
  • Giuseppe
    • Sep 2018
    Dear Community,
    i have one problem in login phase. My zabbix solution is 3.4.14, Server version: 10.1.34-MariaDB-0ubuntu0.18.04.1 Ubuntu 18.04, last update was make in 3/09/2018 and then reboot the machine. All has work!!
    From yesterday have this issue: No permission for system access. Have no way for login except guest mode. No single sign on access is possible, but is configured correctly (has work since 2 day ago), no local access is possible, i try to reset Admin password through DB access (update zabbix.user set passwd=md5('password') where alias='Admin')
    I need your help boys!!
    For now zabbix work only in guest mode...
  • amtbzf
    Banned
    • Nov 2018
    I have the same problem! I don't know how to deal with.
    • ingus.vilnis
      • Mar 2014
      • 908
      Can you execute the following SQL query?
      select authentication_type from config;
      • amtbzf
        Banned
        • Nov 2018
        I upgraded to 4.0 from 3.4 ,then the error only occures when I browse the zabbix web on cellphone or pad.
        • max.ch.88
          • Oct 2018
          • 206
          Maybe clearing your browser cache will help you.
          • chrullrich
            • Jan 2013
            I had the same problem. I fixed it by making a change to the database:
            UPDATE config SET http_login_form = 1 WHERE configid = 1;
            • Janet Kew
              • Jan 2021
              • 11
              This hasn't been helpful for me. I've upgraded to Zabbix5.0.7. with mysql database. HTTP authentication is disabled.
              When I am trying to log in from incognito, Zabbix is logging me as Guest user, but when I'm logging from the browser where I haven't deleted cookies, sessions and cache it's logging me how it's supposed to (with super admin credentials)
