Default Dashboard Zabbix Server Health missing in Zabbix 4.0.0
  • Vedajo
    • Dec 2014
    Hello Zabbix Community,
    we installed the new zabbix 4.0.0.
    The documentation mentioned a new Dashboard for Zabbix Server Health but i can not find that Dashboard.
    Neither me or the other zabbix super admins can find it.
    Is there something i have to configure first to see that dashboard?
  • bbrendon
    • Sep 2005
    • 873
    I think this is it. https://imgur.com/a/z3JDWym
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Jason
      • Nov 2007
      • 431
      Is this only for new installs? Just upgraded my 3.2 test server and no sign of this dashboard.
      • bbrendon
        • Sep 2005
        • 873
        Correct. Upgrades don't add data to your system. The upgrade process only changes the schema where necessary. If you want any of the default data that comes in new versions you have to add it manually.
        • Starko
          • Aug 2012
          • 93
          This screen you mention in the screenshot, is part of the offical Template for Zabbix Server itself if I recall correctly.
          The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
          • jackie
            • Jan 2016
            • 37
            The 'Zabbix server health' dashboard looks really nice, but it will be lost when we upgrade our database from 3.0 to 4.0. Sounds like the only way to include it in 4.0 for us is to manually record all the widget configurations and then recreate them by hand. Is there an easier way? If not, it would be really nice in the future to have a way to export/import dashboards and/or widgets, so they could be easily added when upgrading between major zabbix versions.
