Ton of emails from one trigger/multiple events
  • mystycs
    • Aug 2013
    • 56
    I setup a trigger to show me when a windows os agent ping is down.
    My settings are as follows.
    My trigger is
    PHP Code:
    {qb.mycbird.com:agent.ping.nodata(5m)}=1
    If you look at my events it keeps popping up every few minutes this is when i get an email.
    Why does it keep popping up as a problem randomly every few minutes? Shouldn't it be a problem until it is up? Rather than coming up every few minutes causing me to get a ton of emails.
  • mystycs
    • Aug 2013
    • 56
    It looks like im only getting the trigger email, not the recovery email.
    Why is that?
    This is my action
    • coreychristian
      • Jun 2012
      • 159
      When you look at the graph for that item, is the data sporadic or is it showing no data for the entire period?
      In regards to not getting the recovery message, it's likely in your action condition. If it contains 'Trigger value = PROBLEM' you will only get the e-mail when the down event occurs.
