UserParameter timeout
  • vrtareg
    • May 2006
    • 293
    Hi
    I have problems with the UserParameter timeout.
    I created script which checks license count from FlexLM license manager.
    For the big license file checking for the 1 license parameter takes about 16-20 seconds.
    How can i increase timeout value that i can check this parameters?
    Areg
  • navtek007
    • May 2005
    • 100
    I have the same problem. did you find a answer to this?
    • vrtareg
      • May 2006
      • 293
      Hi
      Yes i have.
      I change license server
      Now it work perfectly with the same license.
      Areg
