One server I setup the agent on, it works fine. tried it on two more servers, and they both are leaving the ZBX greyed out in zabbix, its not communicating for whatever reason. If i check the agent log using the debug level 3, i have no errors, just the below.
37773:20181011:142133.020 IPv6 support: YES
37773:20181011:142133.020 TLS support: YES
37773:20181011:142133.020 **************************
37773:20181011:142133.020 using configuration file: /etc/zabbix/zabbix_agentd.conf
37773:20181011:142133.021 agent #0 started [main process]
37774:20181011:142133.022 agent #1 started [collector]
37775:20181011:142133.022 agent #2 started[listener #1]
37776:20181011:142133.023 agent #3 started[listener #2]
37777:20181011:142133.023 agent #4 started[listener #3]
37778:20181011:142133.023 agent #5 started [active checks #1]
but for whatever reason it is not checking into zabbix, ive restarted the agent multiple times. anything else for me to try and look into?
