Actions not fired after update to v4.0
  • ducatimonster900ie
    • Oct 2018
    Hello to everyone
    after updating Zabbix in our production environment from v3.4.11 to v4.0.0 no actions are undertaken upon triggers are fired.
    The update was made compiling Zabbix from sources with the exact same options of the older version:
    ./configure --enable-server --enable-agent --enable-java --with-oracle-include=/usr/include/oracle/11.2/client64/ --with-oracle-lib=/usr/lib/oracle/11.2/client64/lib --enable-ipv6 --with-net-snmp --with-libcurl --with-libxml2 --with-openssl --with-unixodbc
    We also tried configuring a new TEST action for all events and all hosts but the result is the same!
    Is there something we are missing?
    Thanks in advance.
  • zux
    • Sep 2018
    • 97
    can you show some of those triggers? I have not heard that there where any syntax changes.
    What you can try, is the expression calculator (available under expression constructor in triggers)
      • Oct 2018
      Hi
      we have problems with "Actions" not "Triggers".
      Triggers are fired correctly but no configured Actions, like email notifications, are undertaken since the update.
      Thanks.
      • zux
        • Sep 2018
        • 97
        Sorry, I have no idea how I got to triggers
        Ok then, show us some actions.
        Is the alerter process running?
        ps aux | grep alerter
        increase alerter log:
        zabbix_server -R log_level_increse=alerter
        and look in log file.
          • Oct 2018
          Thanks for your support.
          Yes, the alerter is running:
          The output for "ps aux | grep alerter" is the following:
          zabbix_+ 17939 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #1 started
          zabbix_+ 17940 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #2 started
          zabbix_+ 17941 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #3 started
          zabbix_+ 17942 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #4 started
          zabbix_+ 17943 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #5 started
          zabbix_+ 17944 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #6 started
          zabbix_+ 17945 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #7 started
          zabbix_+ 17946 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #8 started
          zabbix_+ 17947 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #9 started
          zabbix_+ 17948 0.0 0.0 5256244 5428 ? S 11:52 0:00 /usr/local/sbin/zabbix_server: alerter #10 started
          The "zabbix_server -R log_level_increse=alerter" command seems not to be supported by v4.0:
          zabbix_server [24765]: invalid runtime control option: log_level_increse=alerter
            • Oct 2018
            Sorry
            corrected last command with:
            zabbix_server -R log_level_increase=alerter
            An "a" was missing!
              • Oct 2018
              We found the following error in the zabbix server log after each trigger is fired:
              query failed: [-1] ORA-00979: not a GROUP BY expression [select e.eventid,e.source,e.object,e.objectid,e.clock,e.v alue,e.acknowledged,e.ns,e.name,e.severity,max(es. suppress_until) from events e left join event_suppress es on e.eventid=es.eventid where e.eventid in (5338685,5338686) group by e.eventid order by e.eventid]
              We are using Oracle in our environment.
              Maybe this is the cause why actions are not undertaken?
                • Oct 2018
                The working query is:
                select e.eventid,e.source,e.object,e.objectid,e.clock,e.v alue,e.acknowledged,e.ns,e.name,e.severity,max(es. suppress_until) from events e left join event_suppress es on e.eventid=es.eventid where e.eventid in (5338685,5338686) group by e.eventid,e.source,e.object,e.objectid,e.clock,e.v alue,e.acknowledged,e.ns,e.name,e.severity order by e.eventid
                Maybe this should be reported as a bug?
                Thanks.
                • vso
                  vso commented
                  This is already fixed in 4.0.1
