Database seems to be growing too quick
  • ingus.vilnis
    • Mar 2014
    • 908
    #61
    You were fundamentally missing the mysqldump command vs mysql. that single transaction is just addition good to have.
    • fsousa
      • Aug 2017
      • 99
      #62
      In my previous post I've pasted the wrong command, the right command I insert is: mysqldump --single-transaction -u root -p zabbix > db_zabbix.sql
      • ingus.vilnis
        • Mar 2014
        • 908
        #63
        Then you don't need to run it again. Single transaction should have no effect whether you are having some table in the dump or not.
        • fsousa
          • Aug 2017
          • 99
          #64
          I don't understand why my ibd files aren't dumped.
          • ingus.vilnis
            • Mar 2014
            • 908
            #65
            In case you recover to empty database I think you needed to create the DB schema first (as from the Zabbix installation steps but without data) and then import the backup.
            • fsousa
              • Aug 2017
              • 99
              #66
              Thank you Ingus. I will try that
              • fsousa
                • Aug 2017
                • 99
                #67
                Hi Ingus,
                I didn't any feedback because I've some troubles to put my database in my test environment.
                Here the things I've tried:
                • dump my database and then recover to empty database (DB schema created): without success, because my ibd files didn't appear
                • rsync my zabbix in /var/lib/mysql/ to my other server: without success , when I tried to select any table I get "Empty set"
                • ingus.vilnis
                  • Mar 2014
                  • 908
                  #68
                  I believe you should look up some tutorial how to restore complete DB from backup.
                  • fsousa
                    • Aug 2017
                    • 99
                    #69
                    I found the solution for my problem, I've to enable the innodb_file_per_table.
                    Enable innodb_file_per_table vi /etc/my.cnf
                    [mysqld]
                    innodb_file_per_table = 1
                    Apparently when I imported the dump the ibd files per table aren't created.
                    I started to import again my database dump and I've the idb files per table.
                    Thank you.
                    • ingus.vilnis
                      • Mar 2014
                      • 908
                      #70
                      What version of MySQL are you using that this setting is still off by default?
                      • fsousa
                        • Aug 2017
                        • 99
                        #71
                        mysql --version
                        mysql  Ver 15.1 Distrib 5.5.60-MariaDB, for Linux (x86_64) using readline 5.1
                        • ingus.vilnis
                          • Mar 2014
                          • 908
                          #72
                          Ok... at least you got this little issue resolved.
                          • fsousa
                            • Aug 2017
                            • 99
                            #73
                            Yes
                            I began the import of my dump yesterday and then I will try the partitioning of my tables.
                            • fsousa
                              • Aug 2017
                              • 99
                              #74
                              After 2 days partioning my history table I got the following error:
                              [SOLVED] ERROR 1206 (HY000): The total number of locks exceeds the lock table size
                              I google it and it seems are related with innodb_buffer_pool_size parameter in my.cnf. But I'm not sure the value I have to put here
                              • ingus.vilnis
                                • Mar 2014
                                • 908
                                #75
                                This article will give you a good insight.
                                https://www.percona.com/blog/2014/11...-mysql-zabbix/
