Monitoring > Overview not showing Triggers
  • failanas
    • Oct 2018
    I have installed Zabbix 4.0.1 and it doesn't show my hosts at all.
    Automatically discovered hosts are okay, but manually added does not appear.
    If I choose Type: Data then everything is okay, but Type: Triggers does show auto discovered only.
    See attached screenshots, any ideas are very welcome.
  • Atsushi
    • Aug 2013
    • 2028
    Please check the filter setting.
    By default the only things that have changed recently are displayed.
    If you want to display everything, try select Any with the show option and applying it.
    • failanas
      failanas commented
      Any is selected already, that's the problem.
  • L337BEAN
    • Nov 2018
    I am experiencing the same issue described above. I have attached a screenshot of my filter which I believe are correct.
    This issue has only started occuring after upgrading to v4
    zabbix_server (Zabbix) 4.0.1
    Revision 86073 29 October 2018, compilation time: Oct 29 2018 13:39:48
    • ArtursL
      • Nov 2018
      • 167
      I was able to reproduce the issue on my setup. I've submitted a bug report regarding this.
      • L337BEAN
        • Nov 2018
        Thanks for testing this. Would you be able to provide a link to the bug report you've submitted please?
        • ArtursL
          • Nov 2018
          • 167
          Sure, no problem. You can find the bug report Here
