After upgrade to Zabbix 4 receiving erros in the log
  • carlosevp
    • Aug 2018
    After upgrade to Zabbix 4 receiving "Error of query maxQueryMetrics: Permission to perform this operation was denied" in the zabbix_server.log
    Environment: Red Hat Enterprise Server 7.5, PostgreSQL 9.2.23
    Any ideas?
  • Mike2K
    • Oct 2018
    • 60
    Have you look at the log from your database server? Guessing your zabbix DB account is trying to perform a type of query for which it doesn't have rights...
    • carlosevp
      carlosevp commented
      Thanks Mike, not the DB this time - was a VMWare permission for some new checks implemented in the new zabbix version. Thanks for your suggestion though.
  • zux
    • Sep 2018
    • 97
    This is a new query, zabbix does this internally, if you use vmware monitoring. I believe, if you have upgraded vmware from previous versions, the user does not have permission for that query (as it did not exist in previous versions of vmware.
    Take a look at this:
    Error: "Request processing is restricted by administrator" in performance charts tab in vCenter 7.x/8.x
    • carlosevp
      carlosevp commented
      Thanks Zux, that seems to be the problem - some additional VMWare permissions were needed.
  • BiMW
    • Jun 2018
    • 24
    Any ideas?
    What exactly did you make?
