zabbix agent on opensuse 10
  • etsahi
    • Nov 2018
    hi
    i have installed zabbix agent from source and i am getting network , cpu and memory graphs
    i dont see any mounts related triggers , graphs or anything else
    the agent it seems is ignoring disks
    what can i do to fix it?
  • zux
    • Sep 2018
    • 97
    id the agent works, it just works, you need to look at the host configuration in server, to see why you're not getting data for disks (discovery rule?)
    • etsahi
      • Nov 2018
      zabbix_get shows me the correct mounts but i dont nothing in the server side
      • zux
        • Sep 2018
        • 97
        is the discovery rule enabled?
        • etsahi
          • Nov 2018
          yes discovery is enabled and i ran it manually with no effect
          • zux
            • Sep 2018
            • 97
            run this on zabbix server:
            zabbix_get -s <your host here> -k vfs.fs.discovery
            if it returns results, then you might have problems with discovery rule filters
            • etsahi
              • Nov 2018
              well i checked zabbix_get gives you full mount list
              discovery rule filter looks ok
              • zux
                • Sep 2018
                • 97
                then, the only thing I can guess is the item prototypes, are they correct?
                • etsahi
                  • Nov 2018
                  i have checked item prototypes and compared it to a server that reports fs
                  it looks ok
