Hi Sir,
I have Spring boot java application running on linux machine at specific Port. Its a API application (do not have web interface) and getting build using Maven. I want to monitor this application like Memory pool but did not getting any configuration. Initially, DO not want to include anything inside my code but if it will be compulsory to be include some zabbix server related configuration inside code as well then its ok.
But, Please suggest a way to do that. I am new on zabbix and currently only Infrastructure like RAM,CPU is getting monitor. Java monitoring is required.
Help asap !!!!
Help asap !!!!
