SNMPTT Not properly translating SNMPv1 Traps
  • tkr65536
    • Nov 2018
    I'm using SNMPTT to translate received traps from devices on my network.
    The command snmptranslate -m +ALL OID will fully translate the OID into it's short description (MIB_NAME::OID_NAME).
    SNMPTT will translate everything up to the last grouping, and then leave me the numerical value of the last term (MIB_NAME::OID_PARENT_NAME::12345)
    SNMPTT is running with "mibs_environment = ALL" in the snmptt.ini and can properly translate most traps.
    Do you know what may be happening?
  • tkr65536
    • Nov 2018
    Hi, I just wanted to follow up and see if anyone had suggestions on how to fix this problem.
    Thank you very much.
