check_port in Win32
  • jmelus
    • Sep 2004
    check_port in Win32
    Hi !!!
    I have been trying to use check_port[22,192.168.1.1] in Windows. When the host or the port is down, the agent never return any value.
    Is there any error in the function in Win32 ???
    Thanks.
    Jorge
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Not supported under Win32
    Parameter check_port[*] is not supported by Win32 agent according to ZABBIX documentation. See http://www.zabbix.com/manual_config_items.php for more details.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • inhayn
      • Sep 2004
      • 13
      Use this:
      tcp,<port>. (Simple check - without agents)
      Perhaps this helps.
      inhayn
      • jmelus
        • Sep 2004
        Ok, thanks.
        Somebody have modified the function to allow the use of check_port with another host in Win32?
        If nobody have modified it I will write two functions:
        check_port to other hosts
        icmpping to other hosts
        I need to do pings from one host that has the agent installed, but the zabbix server can't access to the end host.
        Jorge
        • bbrendon
          • Sep 2005
          • 873
          tcp,port exists?
          Originally posted by inhayn
          Use this:
          Perhaps this helps.
          inhayn
          Is this really suppose to work? I just tried it. The port responds when i telnet to it but tcp,port is giving me a 0. i'm using zabbix 1.1b6.
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • safl
            • May 2005
            • 103
            tcp,port doesn't work in beta6, i've tried to make people aware of this, in this thread:
            But no replies. But the "simple check", "tcp, port" does not work.
