icmpping and icmppingsec
  • vrtareg
    • May 2006
    • 293
    Hi
    "icmpping" and "icmppingsec" items are not working in my new created template.
    "http" item is working Ok.
    Please help me how can I configure this items.
    Areg
  • abi
    • Jun 2006
    • 81
    i remember something with those items if the hostname was used
    instead of the ip address, search the forum.
    Not sure if this is still the case.
    • vrtareg
      • May 2006
      • 293
      I try to search
      But there are no answer.
      I try both: use hostname and use IP address.
      Both of them perfectly pings from the server.
      I try to ping both from "root" and "zabbix" users.
      This items dont want to work under zabbix server and i dont understand why.
      There are no error messages even in log file.
      Areg
      • vrtareg
        • May 2006
        • 293
        Hi
        Problem solved.
        You need to install "fping" program to ping hosts.
        Also you need to set setuid that zabbix user will be able to run fping.
        "chmod +s /usr/sbin/fping"
        Regards
        Areg
        • mary nancy
          • Jul 2005
          • 125
          hi
          I have a question....If we install fping can we use icmpping without the agent installed on the clients
          Regards
          Nancy
          • RohrbaGe
            • Aug 2005
            • 167
            yes, I'm using that icmppingsec a lot to check simple devices.
            • bleedingpegasus
              • Sep 2006
              This seems to be working, because i can see the return value (using icmppingsec), although its very small 0.001 - 0.01.
              But how come I can't see any graph? (Monitor -> Latest Data -> Graph (in the items list)). Should i expect some kind of green-line in the graph? because the table just empty.
              • mkaser
                • Sep 2006
                icmppingsec has no graph
                After getting fping installed and configured I am getting good data for the icmppingsec but no graph.
                • RohrbaGe
                  • Aug 2005
                  • 167
                  Look at the data typ, you are storing.
                  Must me numeric float, and customer multiplier and a factor,
                  or switch <nomutiplier> on
                  Ro
