Problem with zabbix mysql install
  • tieulong043
    • Apr 2014
    I try to install ZABBIX with tut: https://www.zabbix.com/documentation..._from_packages
    But in this step:
    PHP Code:
    # apt-get install zabbix-server-mysql zabbix-frontend-php
    I get error:
    PHP Code:
    The following packages have unmet dependencies:
    zabbix-server-mysql : Depends: libsnmp15 (>= 5.4.3~dfsg) but it is not installable
    E
    : Unable to correct problems, you have held broken packages.
    Then, i install libsnmp15, but it shows:
    PHP Code:
    Package libsnmp15 is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    However the following packages replace it
    libsnmp30:i386 libsnmp30 libsnmp-base
    E
    : Package 'libsnmp15' has no installation candidate
    I use ubuntu 13.10, and already installed libsnmp30, Zabbix require libsnmp15.
    Any solutions for me?
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello!
    Just curious, are you installing the older Zabbix 2.0 version on purpose since the latest one is 2.2.3 now?
    Best Regards,
    Ingus
    • ingus.vilnis
      • Mar 2014
      • 908
      Try installing this:
      sudo apt-get install libsnmp-dev
      then run again
      and see if it helps.
      • tieulong043
        • Apr 2014
        then run again
        Thanks for your suggets, but it's still not work.
        • tieulong043
          • Apr 2014
          Hello!
          Best Regards,
          Ingus
          I try to install zabbix 2.2, but get the same error.
          • ingus.vilnis
            • Mar 2014
            • 908
            I wonder what is causing this issue. I could successfully accomplish this task yesterday on my virtual Ubuntu 13.10 desktop.
            Is your Ubuntu up to date?
            sudo apt-get update && sudo apt-get upgrade
            • MediaServe
              • Sep 2014
              For me, the following worked to update Zabbix without libsnmp15:
              cd /usr/local/src/
              apt-get build-dep zabbix
              apt-get source zabbix
              cd zabbix-*
              dpkg-buildpackage -uc -b -j2
              cd ..
              dpkg -i zabbix-server-mysql*.deb zabbix-agent*.deb zabbix-frontend-php*.deb
              • jjbarrows
                • Jan 2015
                But in this step:
                PHP Code:
                I get error:
                PHP Code:
                E
                PHP Code:
                E
                I had this same error and realised I had set up the APT source for debian instead of for ubuntu - you may have a similar misconfiguration
                • sagarbirla
                  • Feb 2016
                  Create a link to libsnmp30
                  sudo ln -s <location to libsnmp.so.30> /usr/local/lobsnmp.sp.30
                  should work
