Problem with accessing JSONPath in Dependamt Item
  • hussar
    • Aug 2016
    So I have a Item which returns me a JSON.
    This is the JSON I'm getting (here in formatted version)
    "peers":[
    "id":0,
    "server":"172.16.X.22:80",
    "name":"172.16.X.22:80",
    "backup":false,
    "weight":1,
    "state":"up",
    "active":0,
    "requests":0,
    "responses":{
    "1xx":0,
    "2xx":0,
    "3xx":0,
    "4xx":0,
    "5xx":0,
    "total":0
    "sent":0,
    "received":0,
    "fails":0,
    "unavail":0,
    "health_checks":{
    "checks":15193,
    "fails":0,
    "unhealthy":0,
    "last_passed":true
    "downtime":0
    "id":1,
    "server":"172.16.X.23:80",
    "name":"172.16.X.23:80",
    "backup":false,
    "weight":1,
    "state":"up",
    "active":0,
    "requests":0,
    "responses":{
    "1xx":0,
    "2xx":0,
    "3xx":0,
    "4xx":0,
    "5xx":0,
    "total":0
    "sent":0,
    "received":0,
    "fails":0,
    "unavail":0,
    "health_checks":{
    "checks":15194,
    "fails":0,
    "unhealthy":0,
    "last_passed":true
    "downtime":0
    "id":2,
    "server":"172.16.X.24:80",
    "name":"172.16.X.24:80",
    "backup":false,
    "weight":1,
    "state":"up",
    "active":0,
    "requests":0,
    "responses":{
    "1xx":0,
    "2xx":0,
    "3xx":0,
    "4xx":0,
    "5xx":0,
    "total":0
    "sent":0,
    "received":0,
    "fails":0,
    "unavail":0,
    "health_checks":{
    "checks":15193,
    "fails":0,
    "unhealthy":0,
    "last_passed":true
    "downtime":0
    "keepalive":0,
    "zombies":0,
    "zone":"ca-prod-80"
    What I do is that I want to extract from that JSON values like sent, received.
    So in the Dependant Item I choose JSONPath in the preprocessing and I do $.peers[0].sent
    At least that is my conclusion how I should access data from zabbix documentation.
    But then zabbix gives me a finger with a following error:
    21931:20181206:112716.686 [Z3005] query failed: [1452] Cannot add or update a child row: a foreign key constraint fails (`zabbix`.`item_preproc`, CONSTRAINT `c_item_preproc_1` FOREIGN KEY (`itemid`) REFERENCES `items` (`itemid`) ON DELETE CASCADE) [insert into item_preproc (item_preprocid,itemid,step,type,params) values (539790,null,2,12,'$.peers[0].sent'),(539791,null,2,12,'$.peers[0].sent'),(539792,null,2,12,'$.peers[0].sent'),(539793,null,2,12,'$.peers[0].sent'),(539794,null,2,12,'$.peers[0].sent'),(539795,null,2,12,'$.peers[0].sent'),(539796,null,2,12,'$.peers[0].sent'),(539797,773857,2,12,'$.peers[0].sent'),(539798,773858,2,12,'$.peers[0].sent'),(539799,773859,2,12,'$.peers[0].sent'),(539800,773860,2,12,'$.peers[0].sent'),(539801,773861,2,12,'$.peers[0].sent'),(539802,773862,2,12,'$.peers[0].sent'),(539803,773863,2,12,'$.peers[0].sent');
    What I do wrong ?
    When I have simple JSONs without several nested levels, JSONPath works OK, but when there is a nested multiple level, then zabbix is crying.
    Zabbix version I use is 3.4.6
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    This looks like a bug, I'd report this in https://support.zabbix.com . Other than that, are you using LLD (low-level-discovery)?
