Monitor file age naming issue
  • Awad
    • Dec 2018
    I wants to monitor the age of a specific file, the file path is: D:\BI\Data\Tes - New.File.12580b5634df4be38ddba7fb58dc47c8
    I was able to do this by writing the below under Zabbix WebPortal 'Key' field:
    vfs.file.time["D:\BI\Data\Test - New.File.12580b5634df4be38ddba7fb58dc47c8",modify]
    The problem is that part of the file name "12580b5634df4be38ddba7fb58dc47c8" keeps changing from time to time, due to this, I was thinking if there is any way to monitor the file by adding the asterisk (*) like the below;
    vfs.file.time["D:\BI\Data\Test - New.File.*",modify]
    This didn't work as Zabbix didn't find the file.
    Please advise if there is any way to do this through Zabbix.
    Thanks,
  • ArtursL
    • Nov 2018
    • 167
    What you could do in this situation is create a script on the server that returns the age of the file and gather the values by creating a UserParameter item in Zabbix.
    You could read more about UserParameter items here - https://www.zabbix.com/documentation...userparameters
    • sancho
      • Mar 2015
      • 301
      Hi Awad,
      Using Unixutils for windows http://unxutils.sourceforge.net/
      You can create a key system.run with this line dir D: BI\Data\Test-New.File.* | gawk "FNR== 6{print $1","$2}"
      system.run[dir D:FBI\Data\Test-New.File.* | gawk "FNR== 6{print $1","$2"]
      Or create the same with UserParameter as ArtursL says.
      Depending on the result of the "dir" you may have to change the parameters.
      • Awad
        • Dec 2018
        Hello Sancho and ArtursL,
        Kindly note that I am new in Zabbix, and need help on how to create the script etc.
        I have downloaded both UnxUtils.zip and UnxUpdates.zip, extracted them together, but don't know what and how to do next.
        Please help.
        Awad
        • sancho
          • Mar 2015
          • 301
          Awad,
          In the last update of zabbix there is a new item that you can use vfs.dir.count
          For unixutils, you have the executables in the path:
          UnxUtils \ usr \ local \ wbin
          You can add the route in the environment variables or execute them indicating the full route.
